VW golf 1.6tdi ecu
Results 1 to 5 of 5
    Jan 2016
    Default VW golf 1.6tdi ecu
    Hi, i have a 2011 golf 1.6tdi and the kess v2 unit, i have ecu id the car and it shows up as locked, however i was wondering if i could read the ecu file while it's locked or i can use the option in the kess v2 tool menu to unlock it and read or write. The only reason why i'm skeptical is one i don't want to brick the ecu and 2 it has to eventually go back for that emissions software update at volkswagen sometime in june onwards. Should i unlock the ecu and read or write or shall i leave it until volkswagen does emissions update?
    golf 1.6tdi bluemotion
    HW: CAYC
    SW: 03L906023MN
    EUROPE
    Yes you can read it while is locked but for writting you must unlock it first.If vw update it then you must reflash it again with your mod file
    Jan 2016
    Thank you!
    mastaflex's Avatar
    Jan 2009
    FR47310
    sorry , don't reflash it with your mod file but you have to remod the reading after the update
    EUROPE
    Quote Originally Posted by mastaflex View Post
    I think thay you can write the mod file because the update will be for only emission trick.but to be sure 100% must back up the new file and then can play
