Need help for mjd6f3.b1 Fiat 500 DPF off
Results 1 to 10 of 10
    Feb 2016
    Lightbulb Need help for mjd6f3.b1 Fiat 500 DPF off
    Hello guys,
    I search somebody for help me to disable the DPF and EGR of my Fiat 500.
    It's a 1.3 mjet 75HP with the Magneti Marelli MJD6F3.B1
    I found a damos for the mj8df but nothing for mine. If someone wants the mj8df damos I can post it .
    I have extracted the ori file with my galletto v54 but I can't find the DPF map on Winols 2.24, yeah I know I'm a newbie.
    This is my ori file: ori fiat 500 75hp mjd6f3.b1.zip
    For the EGR I find a french tutorial but for DPF I find nothing.
    This is the link for the Egr:
    http://www.lesamisdelaprog.com/rge-e...t-marelli.html
    What do you think about it
    Thanks a lot!
  2. The Following User Says Thank You to Dionisio2 For This Useful Post:
    bms971 (14th January, 2023)
  3. #2
    Top Poster totalfree's Avatar
    Default FIAT
    Try and report.
    Press the button if my post was helpful.
  4. The Following User Says Thank You to totalfree For This Useful Post:
    Dionisio2 (26th February, 2016)
  5. #3
    Feb 2016
    Thank you very much !
    I will test it on 1000km before making my report.
  6. #4
    Feb 2016
    I tried to inject your file but apparently my Galletto v54 didn't inject anything, while giving me no error whatsoever... Pretty strange.
    I dumped my ECU again and checked the file. It's exactly the same as my ORI. I checked your file and of course it is well modded, but the checksum is different from the ORI. I tried to correct the checksum via WinOLS 2.24 but I doesn't work. The software tells me that the checksum is not valid, and that it's going to correct it. It seems to be working, but then when I export the file, it hasn't changed a thing.
    I don't know what to do. Do you know how to correct the checksum ? It should be "D20E". I looked literally everywhere, and followed many tutorials.
    I event tried to start from the ORI, applying every change you did to the file, and then let the soft correct the CS, but with no success so far.
    Could you please help me get this over with ? It would be very much appreciated.
    Jun 2012
    When you read this ecu, your tool does not read the file on your ecu, but it take the file ori from its database. It's a virtual read. That's why the file that you have read is exactly same to your ori file.
  8. The Following User Says Thank You to cawadany For This Useful Post:
    eculevel (31st October, 2017)
  9. #6
    Feb 2016
    Wow, thanks ! The f*cking time I lost though
  10. #7
    Feb 2016
    By the way, just for information for the future, is there a way to erase this in-memory dump and do a fresh dump ? Thanks again.
  11. #8
    Feb 2016
    Hi, I don't like to up, but please I need this answer
  12. #9
    Oct 2016
    i have some questions about this ecu:
    if galletto read " virtual read " can galletto write another dump to this ecu modifed dump?
    Can someone share pinout for this ecu for galletto?
    can this ecu be read with bdm100?
  13. #10
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    you can read-write this ecu with galetto only on bench (have to open it)
    like (http://www.digital-kaos.co.uk/forums...Marelli-mjd6f3)
