Page 9 of 12 FirstFirst ... 456789101112 LastLast
Results 121 to 135 of 180
Thread: Opel CD40 USB
  1. #121
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by username0815 View Post
    my customer is an opel dealer, can he divorce and marry it in the car? I dont want to write something in flash because i can not test it.
    First of all chech the state of new radio, if it's in delivery state, just pair with display using code 6467.
    If not (I.D. OK), you should put in in delivery state, the simplest way is to write modified dump into eeprom
    shooting posted for you dump, that is already paired with your display. Just white it into eeprom and "Plug&Play"
  2. The Following 2 Users Say Thank You to bank For This Useful Post:
    Decode Ghost (26th April, 2018), username0815 (26th April, 2018)
  3. #122
    shooting's Avatar
    WALES
    Thanks a lot No Code needed? or something?
    Just use my dump..... it is clone of your old radio
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  4. The Following 3 Users Say Thank You to shooting For This Useful Post:
    bank (26th April, 2018), Decode Ghost (26th April, 2018), username0815 (26th April, 2018)
  5. #123
    Nov 2017
    OK thanks than i will write shootings dump, thx for explaination
  6. #124
    Feb 2013
    UK Bristol
    Hello Lads.
    Radio Delphi CD40 Usb
    It is any chance knows pin code and Deactivate Theft Protection and knows pin code
    i tried one dump from some post here with deactivated Theft protection but dont know why, but radio BEEP what 5-7 seconds
    will be the best if new file will be with GID 0610 code
    My post helps you? Please Hit Buttons
  7. #125
    shooting's Avatar
    WALES
    Quote Originally Posted by pocinas View Post
    Hello Lads.
    Here is your dump unregistered, pair using display pin (0610)
    and for future, never use random files off the forum... it's just crazy!
    wbr
  8. The Following 3 Users Say Thank You to shooting For This Useful Post:
    golo (9th March, 2019), irfa (9th March, 2019), pocinas (9th March, 2019)
  9. #126
    Feb 2013
    UK Bristol
    Quote Originally Posted by shooting View Post
    wbr
    Well Done Job My friend.. All works Good, just have Beeps still after activation Theft protection, but i used older OPCOM Software then i choose identyfications CDC40 OPERA and used again Activation Theft Protect, then BEEPS gone.
    :-D
  10. The Following User Says Thank You to pocinas For This Useful Post:
    cone96 (17th August, 2021)
  11. #127
    Feb 2013
    UK Bristol
    P.S you is able do this the same With Delphi Grundig CD30?
  12. #128
    bank's Avatar
    Feb 2017
    Ukraine
    It can be done for cd30 too
  13. #129
    shooting's Avatar
    WALES
    Yes....
    wbr
  14. #130
    Feb 2013
    UK Bristol
    Hello Lads again.
    So can you do this the same in Radio CD30, Deactivation Theft Protection and i would like know PIN, PLEASE :-)
  15. #131
    shooting's Avatar
    WALES
    Hello Lads again.
    Here you go unregistered, for PIN post display dump
    wbr
  16. The Following User Says Thank You to shooting For This Useful Post:
    pocinas (11th March, 2019)
  17. #132
    Feb 2013
    UK Bristol
    Hi There.
    I need help (unregistering) with another 2 radios Delphi-Grundig Radio CD30 Mp3.
    Will very greatfull for this.
  18. #133
    bank's Avatar
    Feb 2017
    Ukraine
    Unregistered
  19. The Following User Says Thank You to bank For This Useful Post:
    pocinas (21st March, 2019)
  20. #134
    Feb 2013
    UK Bristol
    Quote Originally Posted by bank View Post
    Unregistered
    WOW, Very fast :-) thanks a lot
  21. #135
    Sep 2018
    I'll send you correct software in PM
    wbr
    I have the same problem!!! Can u help me? Please?
    I read the EEPROM and through Pecky's program, it tells me that the code is the 6200.
    But since I have this problem in the list, I can not access the radio properly so I can program!
    I have OPCOM and VAUXCOM but I do not recognize the equipment.
    I tried to choose the last CDC40 Opera that appears, I tried to unseal once with this code (6200) and said that it was done successfully.
    The radio started again, but it stayed the same.
    The message "DISPLAY SAFE" will continue to appear as before.
    Because I had already misfired the CID with my old radio.
    Someone can help me?
    Or send me the .BIN file with reset done?
    I would appreciate help with this and what steps to take with OPCOM to program properly.
    Best regards.
