Read somewhere the parental controls or something similar need disbling
Got new openbox v8 Pro and can't seem to get it to work with my VM broadband connection, I know the box is okay because I have been tethering with mobile all day watching the football. When I try & use my VM with either the ethernet cable or use the wifi dongle it works for a minute or so then shuts off and I loose the connection with the channel. Tried disabling firewall on hub and still no luck, don't know what to do now if anyone has any ideas.
Make sure your firewall is set to low in your superhub
Already turned of parental controls and Firewall.
@DW190 Are you talking ablout the changing Virgin Hub settings or on my openbox because I couldn't where its possible to change DHCP on the super hub. Cheers
That hasn't seem to work, I do keep getting message "network cable in & network cable out" then goes back to this Encrypted Program.
Work for a minute then shuts off? Does the picture actually freeze on the screen? if it does, try the box without the sat cable in. If you can then get into the menus without it freezing then there is another known issue with one of the files that is in folder that is out of the bounds of discussion on the forum.
Try googling issues with V8 and (******)
Reading your original post again. It worked OK tethering from your phone That would suggest its the first problem I mentioned with Virgins DNS.
Just sent PM
Have the same problem did you find a solution?
Reboot your virgin hub and the v8 box at the same time and you will see the result.
Still the same. The virgin hub goes red and shuts off when the box is on for less than 1 minute
[QUOTE=Shanew9422;2801387]Still the same. The virgin hub goes red and shuts off when the box is on for less than 1 minute[/QUOTE
Im with virgin and super hub wired connection downstairs and wirless connection up stairs on both v8s boxes, and never had any problems at all. Sounds to me like it your hub is knackered, is it the super hub 3 by any chance?
