Results 1 to 1 of 1
    Aug 2013
    uk
    Default atego ecu 93c86 dump erased...???? welcome comments to help point me to fix.
    i have ecu which fault of ecu was that i couldnt code keys for this.
    i was going to try immo off but either erased the chip or the chip got currupt. now its empty.
    nothing...
    what are my options for this.
    read out 29f400 ?? then what?
    find a working flash 29f400 and 93c86 dump with key and reprograme key with zedbull or other?
    or can i use just 93c86 dump from another ecu as the same part number etc and reprogramme?
    93c86 immo off dump available??
    if anyone has any info to help me or even point me in the right direction would be great.
    thanks in advance
    : 068 447 76 40 ZGS 001
    93c86 eeprom
    29f400 flash
    pictures are attatched hopefully 20160307_121125[1].jpg20160307_121114.jpg20160307_121152.jpg2016-03-07 12.14.08.jpg20160307_121204.jpg
    Semi solved.... dump was ok...
  2. The Following User Says Thank You to thayer201 For This Useful Post:
    albdiag (12th September, 2017)
