Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 99
  1. #46
    That doesn't answer my question (implicit) about the .bmp files - why aren't there any to go with these?
    So do you suggest to just install the Premium files?
    What's with this 'ere dct file - there isn't anything like that on the SD card now - remember this is TomTom 6.
  2. #47
    Member cleggy's Avatar
    Jan 2009
    UK
    The bmp files are contained in the ov2 files.remember these are the tomtom supplied speed cams and are not like ordinary poi files.
    therefore there are only 2 files ie ov2 file which contains all the data and bmp files then the ver file which tells you the version.
    The dct file is needed to authorize the tomtom cameras(basically like a serial number to make a program genuine)
    This is created with either the easytools or the easy activator from my first post.
    VERY IMPORTANT Make sure you save a full backup of your tomtom first so you can always revert if you do anything wrong
    cleggy
  3. #48
    Default speed cam 2010
    Quote Originally Posted by cleggy View Post
    Here is the latest meta files for anybody needing them
    Hotfile.com: One click file hosting
    hi cleggy thx for being a bog support.....the link for Meta file is broken......can u post it again?
    cheers
  4. #49
    Jan 2009
    UK
    leezain
    I did not post any link to the meta files.(so dont know whose link that is,but its nothing to do with me)
    But just in case any body needs them now i have put a link to download the meta file in the first page of this post with the rest of the download links
    cleggy
  5. #50
    Default tom tom
    any chance of a link to the latest uk maps as its the only thing im having problems with and thanks go out to cleggy for the speed camaras easy tools ETC
  6. #51
    Jan 2009
    UK
    redevil
    have sent you a pm.
    Glad you are now sorted ok
    cleggy
  7. #52
    sorry to be a noob, but is there any way to convert these newer .ov2 files to .gpx, or .csv so i can use them on garmin?
    ive used poiedit in the past to do it, but it doesn't want to know with these all in one files.
  8. #53
    Jan 2009
    UK
    you can use poiedit to convert to csv
    i just tried it was ok
    cleggy
  9. #54
    thanks for the reply, i just tried that on safety_cam_uk_premium.ov2, all i get is 'invalid ov2 file'
    if i did get it working, would i get all the embedded bmp files?
  10. #55
    Question.... is there a "how to" FAQ showing step by step instructions on how to put the new maps/cameras/etc onto a TomTom 730?
    I mean.... from step one.. plug TomTom into computer.... step two.. turn on TomTom... etc!
    I have never tried this, and if there was a FAQ on it, it would help greatly.
    Thanks!
  11. #56
    Jan 2009
    UK
    try this
    you may have to register first
    http://www.ipmart-forum.com/showthread.php?t=334471
    cleggy
  12. #57
    DK Veteran bigfella's Avatar
    mick's arse in america
    thanks for all your efforts cleggy, it s much appreciated ..cheers m8
  13. #58
    Nov 2008
    I downloaded the latest camera files and copied them to my device. I then used the easy activator and it ran successfully but the camera files are not picked up by tomtom?
    Any ideas anyone?
  14. #59
    Jan 2009
    UK
    check in your tomtom map folder that you have 3 files for your safety cameras
    ov
    ver
    dct
    if they are there then they are on your tomtom ok
    then checkthe following
    see if the cameras are enabled on your tomtom
    try this
    go to the menu on your tomtom then to tomtom safety cameras
    and make sure alerts are enabled and check the warning preferences are all set to your requirements
    that should help you
    cleggy
  15. #60
    Nov 2008
    Thank you cleggy.
    The 3 files were present but I could not see them in the POI list.
    I went to Menu, then Tomtom Services, Then TomTom Safety Cameras and that did the trick.
    Thank you.
