Tomtom Speed Cameras Updated Regularly
Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 99
    Member cleggy's Avatar
    Jan 2009
    UK
    Default Tomtom Speed Cameras Updated Regularly
    Tomtom Speed Cameras Updated regularly (Weekly when possible)
    UPDATED 6th Nov 2015
    OK I AM BACK WITH SPEED CAMERAS AGAIN
    I HAVE RENEWED SUBSCRIPTION AND AM ABLE TO POST THEM HERE AGAIN
    WILL UPDATE AS REGULARLY AS POSSIBLE.
    THESE CONTAIN ALL THE NORMAL AND PREMIUM CAMERAS FOR ALL COUNTRIES.
    JUST UNZIP AND USE THE ONES YOU WANT
    https://www.mediafire.com/?q0mjq0uz6wjjkjk
    use easytools to generate a dct file to make the maps and speedcameras work.You only have to do it once.
    If anyone else having a problem when just copying the 2 files for their country speedcams into the map folder and them not working.if so check that you are not replacing standard with premium cameras or vice versa.this is because they also use a dct file in the map folder.if thats the case you can use tomtom easytools to generate a new dct file,then copy that into your map folder too and it will work.(You only have to create the dct file once,after that to update the speedcameras on your tomtom ,you just replace the ov and ver files with the new ones everytime an updated one is posted here.)
    Heres my permanent file link for easytools and instructions how to use.You can just use this to generate a new dct file for your speedcameras
    Easytools
    Easytools
    Alternative tool for Activation
    Here is Fast Activate Premium which is an alternative and some people believe (as I do) its much easier and simple to use to patch the Navcore and activate maps Cameras etc.Also updates the meta Just copy it into root of tomtom unit and run it.
    Fast Activate
    Latest-FastActivate
    Unfortunately I am not allowed by my other site to post the link for the latest maps,sorry
    Am glad to be back and able to contribute again
    Enjoy
    Last edited by cleggy; 6th November, 2014 at 10:32 PM. Reason: Speed cameras and fast activate updated
    cleggy
  2. The Following User Says Thank You to cleggy For This Useful Post:
    peko (29th July, 2018)
  3. #2
    Nube question: For space saving can I delete the other countrys camera's?
    Mar 2009
    Many thanks for the update, but how to you 'open' the files so they are visible on the map?
    I have put them into the map folder, but nothing shows.
    Apologies for being a dipstick!
    Mar 2009
    Quote Originally Posted by Eggo_uk View Post
    Yes you can, or even copy/replace will do the trick, but will leave out of date cameras on the map - which may not be a bad thing sometimes.
    Jan 2009
    UK
    pfc01
    use easytools to generate a dct file to make the maps work.You only have to do it once.
    If anyone else having a problem when just copying the 2 files for their country speedcams into the map folder and them not working.if so check that you are not replacing standard with premium cameras or vice versa.this is because they also use a dct file in the map folder.if thats the case you can google for tomtom easytools to generate a new dct file,then copy that into your map folder too and it will work.
    post here if still problems and i will send you how to do it and the easytools link
    Heres a link on this site for easytools and instructions how to use.You can just use this to generate a new dct file for your speedcameras
    http://www.digital-kaos.co.uk/forums...uctions-41875/
    cleggy
    Mar 2009
    Hi Cleggy,
    Thanks for the advice mate. Did exactly as stated, got the DCT entered all into map folder , and the map then did not work, showed up as no map installed.
    Good job I made a back up! Bit of a pain really...
    Any further hints?
    Jan 2009
    UK
    pfc07
    sorry but cannot understand why if you have used easytools and followed instructions that you are still having problems.
    only thing i can suggest is to look at the info on following link
    TomTom Keygen 2009 by BenBBS - {Map Activation & System Patcher} - iPmart? forum
    cleggy
    I've got a problem, I've followed the instructions but I can't seem to find where the .meta file is located, can anyone help?!
  10. #9
    Jan 2009
    UK
    Here is the latest meta files for anybody needing them
    Hotfile.com: One click file hosting
    Last edited by cleggy; 4th September, 2009 at 10:49 AM. Reason: Latest meta file added
    cleggy
  11. #10
    Quote Originally Posted by cleggy View Post
    Thanks very much for that but I'm still having problems (and starting to feel too much like a newbie, I have to admit!).
    The meta file you have provided is called "meta.txt". What am I supposed to do with it? I've tried just inserting it like the easytools instructions say, I've tried renaming to "meta.meta" and I've also tried renaming to "UK_and_IE_plus_major_roads_of_WE.meta" (which is the name of my map.
    If you could give any help I would greatly appreciate it!! Thanks in advance,
    Ash
  12. #11
    Mar 2009
    Thumbs up Garmin ?
    Hi Cleggy, thanks for the camera update. I would love to use the update on my Garmin but every conversion tool (POI Edit, POIconvertor) i try even online ones can't seem to open the ov2 files to convert to Garmin format
    Do you how or could you point in the right direction?
    thanks again
  13. #12
    Jan 2009
    UK
    latest cameras uploaded 6th Sept 2009
    cleggy
  14. #13
    Default Problem with safety cameras
    Hello
    I have placed the safety camera files onto my tomtom but they do not seem to work. I assume I need a new dct file for the cameras but i dont know how to generate one. I tried the keygen but this just gives errors that there is no keyfile in my map. Does anyone know how I can get my tomtom to use the new camera files.
  15. #14
    Jan 2009
    UK
    For everyone who is having problems getting speed cameras to work
    see this link
    Activating TomTom Speedcams :- Method A {insert_meta_from_map_here folder} - iPmart? forum
    you only have to do this once then just replace the 2 files into your map folder as they are available to update them
    cleggy
  16. #15
    Jan 2009
    UK
    Latest cameras now 17th september 2009
    cleggy
