Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 144
    Default Eeprom erraser for 35160wt in new bmw 2016
    Does anybody know what can erase the neue proms in the 2016 BMW
    Mar 2013
    Europe
  3. The Following User Says Thank You to bersch8688 For This Useful Post:
    MV auto (19th May, 2016)
    Sometimes R270 fails for me and does not reset the first two lines (mileage).
    When it fails I use successfully AB-Prog.
    Bests
  5. The Following 2 Users Say Thank You to paskuale For This Useful Post:
    MV auto (19th May, 2016), mvpneu (24th May, 2016)
  6. #4
    I've got DP4 for enigma and none of them can do this 35160WT chip in the 16 plates
    Any one come across this with 16 plates bmw
  8. #6
    May 2016
    Need to heat up chip
  9. #7
    Quote Originally Posted by coz1780 View Post
    Enigma can do this chip only at present
    Sent from my SM-G935F using Tapatalk
  10. The Following User Says Thank You to javyb For This Useful Post:
  11. #8
    smartymarti's Avatar
    Jan 2011
    cornwall
    R270mhas done all that iv done
    All about the Bass
  12. The Following User Says Thank You to smartymarti For This Useful Post:
  13. #9
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    I use these programmer 2 years and works perfect
    http://checkpointlab.com.ua/m35160-eraser/
  14. The Following 3 Users Say Thank You to cokolo For This Useful Post:
    cklair (24th May, 2016), DOUGLASDL (8th September, 2017), MV auto (19th May, 2016)
  15. #10
    Jun 2015
    I also have a problem that my P270 can not erase incremental area 35160WT, although erases M35080-6, 160D0WQ, 160D0WT, 080D0VK. Has anyone found a programmer that erases it 35160WT?
  16. #11
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Not all chips are same...
    There is CHIP ID in every one of them...
    For this some work even is they 35160WT and some not...
    Not posible to change to 160D0WQ as you will get DOT in dash and EEPROM CHIP ID ERROR in diagnostics...
    Live by the rules and die by the rules...
    Thank before you die...
  17. The Following 2 Users Say Thank You to Landetos For This Useful Post:
    javyb (23rd May, 2016), Yhoni (25th October, 2023)
  18. #12
    Jun 2015
    Quote Originally Posted by Landetos View Post
    Maybe possible to change the dump of MB91F467DB? And replace the EEPROM on 160D0WQ. How to read MV91F467DB using UART? How to use an interface? How to connect?
  19. #13
    Mar 2013
    for me 2015 year 06 month work good r270 five times good luck
  20. The Following User Says Thank You to electronicservicemate For This Useful Post:
    rtbdiagnostic (5th November, 2019)
  21. #14
    Quote Originally Posted by electronicservicemate View Post
    What was marking on chip?
  22. #15
    Dec 2010
