you have pm
you have pm
The eeprom 35160 or 160DWT can read ,but can not errased full part
need to do like this ...Read andsave original dump
change eeprom with new empty eeprom
http://www.auto-chips.com/bmw-dashbo...ked_p1703.html
make first 2 lines to 00, adress 000000 to 000020
and Write it
then make New KM and write again
after conectthe dash on car,willnot get red dot, and not have errors with diagnostic( eeprom serial numberfaulty)
try it
rtbdiagnostic (4th October, 2017), tyrystor (14th April, 2019)
I have both smok emulators for 35160WT. For version V2 you can use any programmer but version V1 need to write chip ID from ori 35160WT to the emulator. Who knows which other programmer can do that. Otherwise need buy smok
rtbdiagnostic (4th October, 2017), smartymarti (4th October, 2017), teerak2uk (4th October, 2017)
Only way is to use emulator
I do not think so
Using new IC, write data
Can also solve the problem
erase is posible...tested by me !!! dont say is not posible !!!
Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
Nice for you. But if you don't say how then it's useless for us.
Did you use a digiprog eraser with update by any chance?
My solution is not safe ,,
drpeter (13th December, 2017)
Does R270 reads 35160WT? Does emulator V2 from SMOK works? Any body knows working emulator? where to buy it?
shure it works. but u need smok eraser or smok hid 35080 tool
Lets make it all clear:
160D0WQ - eraseable but also depending on IC CODE - for example - EZ607 code is not eraseable
160D0WT - eraseable and never found an IC CODE that would not be erased by Enigma Super Eraser...
35160WT - eeprom can not be erased - eeprom can not be changed to 160D0WQ or 160D0WT because will show the RED DOT in dash - why? because the internal ID will not match...
35160WT - requires an eeprom emulator and this is the only solution available for now...soon new incomming...
Live by the rules and die by the rules...
Thank before you die...
rtbdiagnostic (5th November, 2019)
f10 f01
Dashboard d160 / 35160
I want to know if there is nothing wrong with changing km here.
I want to know if cas4 can change km
Is it OK to change km only in decibo ............
cas4 no problem correct km. d160/35160 2016 and next cammot erase. need emulator. i use elprosys emulators. works good
