hi
u cannot change chip id in all chips
hi
35160wt erase Guide
richone (18th January, 2019)
Hi, with what you were managed to delete vin in 351650wt?
Does anyne know which line should be erased to clear Vin on 35128?
Hello to all!
Who can assure me a good and working R270 programmer to virginize a 160D0WQ EEPROM from BMW F30 6WA extended cluster?
Better if I can buy it in Europe, to avoid taxes from China..
For me is good also a just programmed (and virginized) EEPROM to swap with the current one.
Your dump has not been read with correct tool. Size is too small.
Dump for 35128 must have 16.134 not 2048.
Can you confirm that I could change the vin on a 35160WT in 2016 kombi with a R270?
No need to change the mileage.
You talk about changing the vin in the 35320 too. I do not think I have this chip but next to the 35160wt, I have a 95080rt.
Is there something to do with it ?
R270 can change the vin without problem. Milage not possible. The other chip should be 95320. For this one use vvdi or any other
160dowt... erase and change mile...100%success wirh r 270
Mini 2016
rtbdiagnostic (5th November, 2019)
Care to share what is the difference ?
Hi all,
I have an issue with a 6WB retrofit. I have a BMW 2011 bmw F10 (without HUD).
I bought a used 6WB cluster with HUD from a guy who took out the (i think) 35160wt eeprom. When I say I think it's because the cluster is manufactured on oct-2015.I don't know if it's 35160wd or 16DOW. The other eeprom -95320WT is present . Everyone I ask says that I will get the red dot on the odometer. What are my options? I saw that there is a
Xhorse 35160DW that eliminates this problem. And what dump should I use?
Thank you.
