hi
yes you will need to flash the dash have done it before with esys
hi
injecting CAFD its sufficient but need to change the vin in the 95320 too.
dlllllllkkk
Codiprog does 160D no problem, it’s the 35160WT that everyone seems to have problems with
Have a small black box
BMW GXX Series M35128 chip renew tool
Anyone know it?
Is it an emulator?
possible with enigma or diagprog4. no need emulator. only 35128et
I'm new here and a bit confused after talking to somepeople about deleting vin number in 6WB kombi. Ihope you guys can help with a few questions.
I have a BMW F10 520d from 2011 where I bought a used 6WB kombi.
My car has driven 165,000 km and the used kombi has driven 66,000km so I havenothing to do here right???? Doesn’t CAS automatic right 165.000km to the kombiwhen I code it for the car ?
But I need to changes the vin number in it….
The used instrument is pretty new, made in January 2018with x71 ( see picture )
Have read 35160WT where I can find short vin number two places, unfortunatelyno long, should there not be a long one ?
Has also read 95320RT where there is one short vin number.
Hope someone can help me, cause can see on the web 35160WTis not possible to erase or some says maybe.
Do I copy 35160WT and remove it, bye an emulator and thensolder it in the kombi and put the copy in, then changes vin to my vin, or 00or FF both vin instead ?
I also need to zero out vin number in 95320RT but that Ican do without any problems right ?
I used carprog.
Attach both eeprom
Regards Jens
just swap eeprom 35160
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
So emulator says id okay even if there is wrong vin number. So just solderthe emulator in and code the kombi with esys that's it?
Some mention you should put the original eeprom dump into it?
Can you clarify your answer a little more :-)
Me Again.
Just a few more questions :-)
Have deleted vin number in 35160wt and 95320 and tried to code it, found outthe missing CAFD file where I found how to CAF select and choose the highest press ok and right click on kombi and code. Went nice and no red dot. Everything works except road sign detection.
Maybe I didn’t choose the right CAF file or do I need more after right Click on kombi and code ?
In CAF selection there is a lot of folders:
F010-17-11-500
F010-17-11-510
F010-17-11-520
F010-17-11-523
F010-18-03-500
F010-18-03-510
F010-18-03-511
F010-18-03-520
F010-18-03-530
I chose F010-18-03-530 and in that one was CAFD 00001060_005_001_051 same number In all folders.
Can I just try to select new CAF file right click and code again or try again with the same?
Anyone knows what to try ?
