Clio III alternator problem
Results 1 to 11 of 11
    pinheiro's Avatar
    Portugal
    Default Clio III alternator problem
    Hi friends
    I have a problem with a Clio III, 1200 - 16 valves, 2007.
    The car had problems with the alternator, it was charging irregularly, causing voltage spikes.
    The alternator was repaired and it's OK.
    Then, the car sometimes gives me the following error, by Clip:
    DF046 (battery voltage)
    and by Texa:
    P0560
    When this error appears, the car begins to fail, it doesn't accelerate.
    I have allready checked connectors, contacts, battery, alternator... - everything OK.
    I have also tryed with the alternator off, and it appears the same code error.
    Could it be a problem with the Ecu?
    Siemens SIM32
    S120200105 A
    820052357
    8200510536
    Regards and thanks in advanced
    Pinheiro
    Mar 2016
    How to charge bateru
    pinheiro's Avatar
    Portugal
    Hi friends
    I have another ecu
    Siemens SIM32
    S120200105 A
    820052357
    8200510536
    To code it, is it just necessary to clone the eprom 95160?
    pos battery terminal has 2 fused links one is cracked
    Slovenia
    Hi all,
    I have the very same problem - df046 or p0560... Pinheiro, did you ever solve this? any ideas? I changed ecu, same issue.
    Best regards,
    Smac_a
    Apr 2017
    If the eger ligature changes, it must be introduced with clip
    Slovenia
    Hi, sorry but what do you mean with "eger ligature"?
    Best regards,
    Smac_a
    pinheiro's Avatar
    Portugal
    Problem solved.
    The problem was in the bcm.
    Best regards
  9. The Following 4 Users Say Thank You to pinheiro For This Useful Post:
    alessioblaupunkt (1st February, 2020), Meat-Head (31st January, 2020), meli (28th February, 2020), racin-snake (31st January, 2020)
  10. #9
    Meat-Head's Avatar
    Under dashboard or under hood
  11. #10
    Yes which one was it, only have same problem, thanks
  12. #11
    Meat-Head's Avatar
    Quote Originally Posted by radiosolutions View Post
    VAGUE MODE:-
    had a reno modus same shit was under hood fusebox
    “small multi plug” thin wire went direct to dynamo
    VAGUE MODE OFF
