Results 1 to 15 of 21
    Slem's Avatar
    Oct 2015
    Default Toyota Crown 2007 smart key all key lost ..
    Hi m8s
    I have Toyota Crown 2007 (Smart Key system with fob slot ) all key lost, I reset the immo only with SKP900 devise and register a new key on it , the car started but the problem is the Lock, Unlock and proximity function not working. I need your help to reset the EEprom 93C76 in the smart box to be able to program the lock, unlock and proximity .. please note that i programmed a used smart key not new and reseting the C76 will allow me to complete the proximity job ..
    93C76(mark x) Crown smart box 89990-30010 original bin attached
    93C76(mark x) crown smart box original 89990-30010.rarFB_IMG_1458675301865-1.jpg
  2. The Following User Says Thank You to Slem For This Useful Post:
    kyawkyaw (31st March, 2016)
  3. #2
    Slem's Avatar
    Oct 2015
    Any help please
    Jul 2015
    Hello m8,
    Try and check your smartkey fob battery if is active. Please change it if is not active your skp900 or X-100 is very good to handle the job. check carefully.
  5. The Following User Says Thank You to aketokediag For This Useful Post:
    Slem (11th April, 2016)
  6. #4
    Oct 2015
    no there's no fault of battery at all, because SLEM is right this vehicle needs smart reset or virginize file in case of proximity working
  7. The Following User Says Thank You to usman4 For This Useful Post:
    triplerkeyservice (4th December, 2016)
  8. #5
    Dec 2013
    Africa
    send your Dump i will reset for you.
  9. The Following User Says Thank You to abvayani For This Useful Post:
  10. #6
    siyadk's Avatar
    Dec 2012
    are you sure the chip you read is correct. isn't it supposed to be 93c86
  11. The Following User Says Thank You to siyadk For This Useful Post:
  12. #7
    Dec 2015
    There is no smart box in this, car, its a simple ID 70 transponder. You do not need any machine to Programme the key fob with, simple Manual programming process.
    Same like we do for a bladed key.
    You can reprogramme new or used fob with out any problem, same like bladed key
    Leave the driver door open
    Like insert the key into slot 2 time and remove it
    close and open the door 2 time
    Leave the door open
    Insert the key in slot and remove it
    close and Open the door 2 Time
    Close the door
    Press the switch button 2 time
    remove the key
    car lock will cycle
    press lock and unlock button togather for 1.5 seconds
    and the fob is programmed
    David Junior
    I
  13. The Following User Says Thank You to davidjunior For This Useful Post:
  14. #8
    Slem's Avatar
    Oct 2015
    Thanks for all the replays .. Usman4 should report the result ..
  15. #9
    Brayn's Avatar
    Oct 2015
    Colombo
    Very late...
    But I can this vehicle model
    Used smart key or brandnew key
    This type keys not Smart key they are Interligent keys.
    93c76 can reset and program keys
    Any one need help post dump file
    Sent from my C5502 using Tapatalk
  16. #10
    Dec 2013
    Africa
    Default Hi Bryan Please Reset For me This Dump
    Hi Bryan i have another Reset Dump for Crown but the Problem is when i press Break Start Button Light Should Be Green.
    but in my Dump i car Start the car but Green Light On Button its not coming On.
    i think my Dump is not for same Car.
  17. The Following User Says Thank You to abvayani For This Useful Post:
    magoti (8th July, 2017)
  18. #11
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by abvayani View Post
    Can Vehicle start?
  19. #12
    Dec 2013
    Africa
    Yes Vehicle start Smart System is also working fine.
    Can you reset for me my dump that the original dump i was send you.
    Sent from my SM-J700F using Tapatalk
  20. #13
    Brayn's Avatar
    Oct 2015
    Colombo
    If vehicle start, also Smart system work why you need reset file??
  21. #14
    Dec 2013
    Africa
    Bcoz i got that dump from my Friend.
    I already programe in 3 cars.
    Only the Problem is On Start Button Green light Should be Come ON when we Press Break.
    And when i press Start Button for ACC Position the light should be Orange Colour but on ACC position Light Come On Green Colour.
  22. #15
    Dec 2013
    Africa
    I have a Dump but That Dump is not for same Car
