Results 1 to 15 of 15
    Oct 2014
    Default Is there any way to clone an AT88SC0104?
    Hello everybody I have 2 fta receivers and this chip got damaged in one of them, I checked by using the chip from the good receiver on it and it worked. I have the programmer and a blank chip but these chips are protected and I can't clone it.
    Meat-Head's Avatar
    That would priberbly involve destroying your working chip
    just try a random dump from simething see whar happens, see if git
    factory reset
    apexseal Newbie
    Oct 2014
    Downloads
    4
    Uploads
    Oct 2014
    factory reset
    apexseal Newbie
    Oct 2014
    Downloads
    4
    Uploads
    A random dump from something?? Could you elaborate a bit more on that please?
    Meat-Head's Avatar
    If the tv,toaster, speedo, clock, washingmachine mcu
    see blank chip, might just sit there.
    put random dump/numberz in dump it might then go
    "WTF do you want to factory reset bro"
    its bin fodder, nothi g to loose
    Oct 2014
    I don't need factory reset bro... I need to dump the at88 from the working stb that turns on so that this one will turn on, this stb uses at88 + flash chip. Can an at88sc0104 be hacked/dumped?
    Oct 2014
    Could this do the job? crack-securememory.rar
    Meat-Head's Avatar
    ON TOPIC:-
    What did you read/write this with?
    Meat-Head's Avatar
    On topic nearly ADVERTISEMENT:-
    http://vi.raptor.ebaydesc.com/ws/eBa...=1483317347117
    read descriltion, not right chip, but nothing to loose
    Oct 2014
    It's a soic encapsulation AT88SC0104 chip not a smartcard type. My Superpro supports it but since I don't have the password to acces the chip I can't read it.
    Meat-Head's Avatar
    Oh, open window and chuck it out
  11. The Following User Says Thank You to Meat-Head For This Useful Post:
    ifred (26th January, 2017)
  12. #11
    Oct 2014
    Bus pirate should help I guess... Giving up is not on my list. If I get it done I'll share.
  13. #12
    Meat-Head's Avatar
    Bus who?
    ON TOPIC:-
    have you tried asking maker to post you prigrammed chip?
  14. #13
    ifred's Avatar
    Bus who?
    ON TOPIC:-
    Maker probably chucked it out the window first
  15. #14
    Oct 2014
    I was able to log comms with the bus pirate.
  16. #15
    Meat-Head's Avatar
    Great, do show more info
  17. The Following User Says Thank You to Meat-Head For This Useful Post:
    pascall22222 (13th November, 2018)
