It looks like the radio is from other vehicle? Then you should connect diagnostic and pair unit with vehicle, because VIN numbers do not match, i suppose.
Hey all,
I want to know if anyone know solution about a RNS 510 with CAN BUS CHIP PROBLEM on motherboard.
Symptom of this are :
- No light button when light turn on
- No communication with car (vcds, mfa, steering wheel button,...
- RNS 510 stop after 30 min.
Anyone saw this before ?
kappa1 (27th June, 2016)
sonices (2nd April, 2016)
OK, what do you meen switch motherboard? Whole board from RNS or ? Did you found what chip is causing problem?
There shoud be a chip with label 3510AA it is TJA1054. Not shure but check it, it is easy to replace maybe it will help
I dont know but it is easy to start repair by replacing it or swapping from another unit, on RNS510 i have never changed, on some other radios i did
yes maybe swapping from another working motherboard this chip.
But you sure this chip is for can bus control ?
TJA1054 is CAN Transceiver and TJA1055 is also CAN Transceiver but TCA1055T i dont know what it is. I dont have RNS510 in my service but when i have it i will explore CAN on it and inform you
attilaa0 (2nd April, 2016)
there is no power supply for TJA1054 after upgrade sw4XXX or more, pin BAT on picture, just bypass pin BAT and VCC, can will start work again, I have tested on may be 20 units...
Actually,problem lies in the ST10.
It is the one who controlls CANbus functions and acts as an Audio Gateway.
