Results 1 to 15 of 21
    nickolasd's Avatar
    Nov 2015
    Default Audi Q7 key stuck in ignition
    got 07 q7 4.2 with bad ecm and key stuck in ignition. engine cranks and starts but dies right away. no communication with any module except ecm, and even ecm communication is very limited.
    trying to figure out how to proceed next. vehicle doesn't have little hole next to key like some euro ones, to get key out.
    rob h's Avatar
    May 2011
    If the voltage is low! This could explain some bad communication.
    I assume that the automatic gearbox is in the park position.
    Charge car, activate hazard lights, and read and clear all dtcs.
    Looks like a the car does not see the gearbox.
    Jul 2013
    hello, you can read dtc of the ecu?
    Also see if you can clear the dtc of the ecm?
    nickolasd's Avatar
    Nov 2015
    i can read dtc out of ecu only and there are non. yes its auto, in a park position. will try to charge.
    vanos batam's Avatar
    Batam-Indonesia
    Bad key..
    Make new key
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Key have nothing to do with this problem. CAN bus problem in car.
  7. The Following 3 Users Say Thank You to lupu_sandu For This Useful Post:
    nickolasd (4th April, 2016), vanos batam (5th April, 2016), yugo45 (4th April, 2016)
    Jul 2013
    friend, this happened to me with a q7 2007, to everything but not start
    ECM has a vent moisture and there entered, you can review it,
    I hope I have helped
    nickolasd's Avatar
    Nov 2015
    i got battery charged, it dint help, same thing key stuck. ecm is bad due to water, it was known from beginning.
    but right now i have every module in some kind of sleeping mode, and can't wake anything up, except edu. cluster is black navi screen is black looks like nothing responding to diagnostics except ecu. i can turn key on and off, i can crank engine and it starts and dies right away. if i disconnect battery and reconnect nothing changes.
    it looks like i need to turn key off all the way and turn it back on to wake modules up, but i can't. activating hazard light or bright lights or both doesn't help because nothing works.
    anybody knows any other way to wake modules up?
  10. #9
    yugo45's Avatar
    Disconnect ECU , then try to turn key on and see what happens.
    If ECU has water in it , it will mess up Can_BUS and cause problem that you have.
    Also possible water get in Can Gateway module.
  11. #10
    In a van down by the river
    Quote Originally Posted by nickolasd View Post
    have you tried jumping power to fuses?
    what modules you are trying to wake up? I think this year Audi Q7 can power cluster by jump power in fuse box.
  12. #11
    Apr 2011
    in lebanon
    Quote Originally Posted by indienick View Post
    Hello.
    no Dear friend, this is not same as vw touareg or Porsche cayenne, the audi Q7 dash wake up by can bus from getaway module by EZS order, i think (nicolasd) must try re-adapt the remote key to ezs to release the remote from stuck in ignition.
  13. #12
    nickolasd's Avatar
    Nov 2015
    i did try to turn key on with disconnected ECU, same problem, tried to remove fuse for cluster and put it back i can hear a click inside but it doesn't wake up. all fuses good and all got power. it looks like every module has power but without command from gateway or whatever module controls everything they all stay asleep.
    how i can re adapt key if i can't communicate with anything.
    anybody knows how difficult to remove EZS, looks like whole dash has to come out
  14. #13
    yugo45's Avatar
    Open your can gateway and look for water damage.
  15. #14
    mihaiservice's Avatar
    http://www.quick-tuning.com
    did you have check if gearbox are in Parking mode ? also you have make a short test drive to check if gearbox not are in limp mode !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  16. #15
    Quote Originally Posted by haroutioun View Post
    Hello.
    Thanks for explaining, i thought the Q7 was same platform as Touareg or Cayenne. Admittedly I never have done work with keys on Q7 until now. Only Touareg. I just remember from my custom stereo days that I did some headrest TV's in both cars and was very similar. Is it same chassis and different electrical?
