Will this work for the dm 500s
OpenPLi 4.0 IPTV GStreamer 1.8.0 by MastaG (v16)
Changes:
- Gstreamer 1.8.0 stable release
- New PLi spring logo
- Upgrade OpenVPN to 2.3.8
- Upgrade OpenSSH to 7.1p2
- Upgrade OpenSSL to 1.0.2g
- Patched and bumped Python due to OpenSSL not supporting SSLv3 anymore
- Upgrade Japhar-IPTV list to 1.6
- Upgrade rtmpdump from oe-alliance and let it provide librtmp as well
- Upgrade ffmpeg to 3.0.1
- Patch for dvbmediasink from mx3L for writing PTS on every PES header
This could possible fix some m3u8 streams freezing
- Removed the patch for dvbmediasink which should fix seeking in some mp4 streams
Since I couldn't reproduce the problem
- Rewrote Dreambox kernel recipes which should fix certain models not booting
- Fixed CrossEPG
- Fixed very large Packages.gz on the server
- Merged latest openpli-oe-core changes
- Merged latest OpenPLi enigma2 changes
- Upgrade oscam to rev 11225 and applied joeuser's latest tryfix oscam-emu patch
Emulating PowerVU should now work for multiple pids
- Lots of stuff I forgot...
DM500HD+ : https://mega.nz/#!NR0hHKhT!fX5cI-pgR...kxX59yZW9wVG4o
toysoft (11th April, 2016)
OpenPli 4.0 IPTV by MastaG / Japhar Team with 1200 FREE IPTC Channels and with GStreamer 1.9.0.1 (April 15th 2016)
Changes:
- New gstreamer 1.9.0.1 recipes based on christophecvr's github (small changes for PLi4)
- Upgrade glib2.0 and some other components like gobject-introspection to satisfy the new gstreamer recipes
- gstreamer1.0-libav is built using it's minimal libav with only support for wma (thank you chris)
It's pre-installed on all receivers except for the ones with only 64MB of flash (dm800/800se/500hd)
- Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Player's exteplayer3 (thx to Taapat for the original bbappend)
Login with telnet and issue: opkg update && opkg install ffmpeg
- Latest openpli-oe-core changes
- Latest enigma2 changes
- spark: libeplayer3 is pre-installed now (also in the feeds) for movie players with support for this library
Note: servicemp3 still uses gstreamer
- spark: some OpenPLi enigma2 backports (since Taapat doesn't maintain his enigma2 branch anymore)
The servicemp3 memleak patch has been applied with some other patches/commits I found useful
- spark: don't force async mode on the dvbaudiosink anymore, it's now the same as all other receivers again
- Add Vu+ Solo 2 Lonrisun V4 (v1 and v2) images + feed
DM500HD+ : https://mega.nz/#!ZwB3wTqI!JjyTk2sAe...TSerbJrtZW8BxY
it works with sim ferrari?
