Results 1 to 7 of 7
    Apr 2016
    UK
    Default Golf 5 2005 1.9 tdi hotstart map
    Hi, if possible could you provide me a hotstart map fix for golf 5 2005 1.9 tdi? Thank you
    golf5-ecu.zip
    ECU Data:
    .0281011900
    BPG-81015.02.0512345
    7811420247
    .wvwzzz1kz5p087482
    2.0281011900
    ..r4 1,9l edc
    v1037371094
    Here you go.
    Apr 2016
    UK
    thank you radoslavwwiklik i am going to try it now and tell you the results
    Apr 2016
    UK
    sorry to tell you but this file isn't working at all i flashed the ecu with the file and the esp light was on and the car didn't start at all.
    My file its ok, your programmer is bad...
    Use bdm and car resurection.
    Apr 2016
    UK
    I am using galleto and i had no problem so far.
    Jun 2012
    Try to restore your file without make ecu-id.
