Page 11 of 14 FirstFirst ... 67891011121314 LastLast
Results 151 to 165 of 210
  1. #151
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Happy New DK members
    Quote Originally Posted by happy_highlander View Post
    No reason to update of nothing is broken. Every now and again update the autobouquet config file from within the autobouquetsmaker menu and you'll be sorted
    Sent from my SM-G935F using Tapatalk
    This is what I do, can't remember when I last did a software update on my H2s, as all I need to do is update the ABM config files, rescan and all my channels are there again.
    Quote Originally Posted by Proz View Post
    I just got caught with the freezing on boot after updating ... the feed status was green so thought id be ok but it did pop up saying its an old image and it may not boot properly . There were 63 updates and the status was green ?
    Anyway I'm up and running again with your image here .
    Is there any reason to update or indeed any reason not to update even if its green status ?
    As the software update was showing green light thought I'd do an update and as you stated the update breaks the image and your Zgemma fails to boot, flash the lastest vanilla openatv image and the zgemma boots correctly, so my backup image isnt compatible with the new software, easy to fix I just need to rebuild an image. However, crossepg 0.6 & 0.8 both dont work with the new images, so it looks like the future image will have epgimport and the EPG plugin.
    I will make a new backup image over the next couple of days, but not to day as I'm nursing the hangover from hell.
  2. The Following 4 Users Say Thank You to martin035 For This Useful Post:
    digicon (1st January, 2017), Hadron (2nd January, 2017), happy_highlander (1st January, 2017), Proz (2nd January, 2017)
  3. #152
    Fife
    Quote Originally Posted by martin035 View Post
    Happy New Year and I hope your hangover gets better .... you can always postpone it by having the "hair of the dog" .
    I look forwards to your new image though as I did try to do mine from scratch but kind of got nowhere .
  4. #153
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Hi Martin using this image on all of my boxes.
    Just a quick question when it boots up it never goes to previous channel or a fixed channel.
    Any idea how I can change this as I've had a look and can't find how to do it cheers.
    Andy
  5. #154
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by andy91 View Post
    Andy
    Press the 'Fav' button and scroll to your channel you want to startup from, press 'Menu' then select 'set as startup channel'
  6. The Following User Says Thank You to martin035 For This Useful Post:
    andy91 (2nd January, 2017)
  7. #155
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Then new image has been built, just doing a bit of testing & awaiting for a picon or two then it should be ready for release.
  8. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    Hadron (2nd January, 2017), Proz (3rd January, 2017)
  9. #156
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Major Software rebuild
    Software Update: Due to the Problems with the old image not been compatible with the new software updates, a new rebuilt was done, Crossepg all version doesn't work so is replaced and a few new picons added
    • New build with original Openatv5.3 image dated 1/1/17
    • Crossepg removed and EPG Import installed
    • Picons updated
  10. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    Hadron (4th January, 2017), Proz (3rd January, 2017)
  11. #157
    Fife
    • Picons updated
    Oooo ... were can I get the new build ? Is it the dropbox link on the first page ??? Thank You
  12. The Following User Says Thank You to Proz For This Useful Post:
    martin035 (3rd January, 2017)
  13. #158
    Fife
    Up and running with the new image and looking good .... Thanks for the work and efforts you put in to this :-)
  14. The Following User Says Thank You to Proz For This Useful Post:
  15. #159
    Aug 2010
    East Midlands
    Hi Martin used this image a few times lately for Vermin but today in Fav ive only got Hd and fta in bouquets.
    There's no selections like entertainment/sport/movies.
    For some reason they're all grouped together.
    Any idea how I can get the categories back cheers
    Andy
  16. #160
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Andy
    Menu-Setup-service searching-providers
    Ensure your ABM settings are as per the pictures attached, mine only shows Sky UK, you will also have to do the same for cable side as well, obviously change 'scottich east custom' to 'your area custom'
    Then
    Delete Bouquets
    Start Scan
  17. The Following User Says Thank You to martin035 For This Useful Post:
    andy91 (14th January, 2017)
  18. #161
    Aug 2010
    East Midlands
    Then
    Delete Bouquets
    Start Scan
    This is on a Cable set up so other than put net id in you can't pick an area like you can with Sly.
    All the times I've done it before it put the proper categories in order.
    Andy
  19. The Following User Says Thank You to andy91 For This Useful Post:
    martin035 (18th January, 2017)
  20. #162
    happy_highlander's Avatar
    Aug 2010
    You do pick your area fir cable on abm same as sly but your area will correspond to your vm tv area
  21. The Following User Says Thank You to happy_highlander For This Useful Post:
  22. #163
    Aug 2010
    East Midlands
    I've picked 00008 which is Nottingham but it only creates 2 bouquets. Hd and fta only.
    There's no sports/movies/factual etc
  23. #164
    Aug 2010
    Settings should look like this. Obviously change the region to suit. Pay attention to the option highlighted in the second screen 20170118_211412.jpg20170118_211440.jpg
  24. #165
    Aug 2010
    East Midlands
    That's how it is so I can't understand. I did put No into Sections and it created 3 bouquets.
    Think when I get a minute will reflash and see if that sorts it.
    Andy
