Page 12 of 14 FirstFirst ... 27891011121314 LastLast
Results 166 to 180 of 210
  1. #166
    Oct 2016
    Hi martin just a quick question, im having some trouble with programs populating on some channels (SlySptBO) for tonight. Any way to resolve this? Tried epg importer again to see that would fix it but no joy.
    As a result it won't show the program that starts at 1am or record it.
  2. #167
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by fm89uk View Post
    Unfortunately, that is a limitation of the epgimport plugin, if the good people at xmltv don't update the info for that channel then nothing will be displayed, way around this is to manually set a timer to record the channel /time
  3. #168
    Oct 2016
    Quote Originally Posted by martin035 View Post
    Thought as much, thanks for the quick reply and your help as always Martin it's much appreciated. I will try to do this, will I be able to do even if program time frame isn't showing?
  4. #169
    Hadron's Avatar
    Nov 2012
    E. London
    Yep. The easiest way to set a manual timer is to tune to the channel you want to record first. This ensures that the correct channel will already be shown when you select manual timer. Press "Timer" on remote & then green to add the details.
  5. #170
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Software Update: Minor update
    • Anggel V2 Picons added
    For those of you not wanting to reflash their Zgemma then the Picon pack is attached, just unzip then FTP to /usr/share/enigma2/picon and delete the contents of that folder and transfer the new picons over.
  6. The Following 3 Users Say Thank You to martin035 For This Useful Post:
    anemeth (4th February, 2017), Angel66 (18th February, 2017), tony_i (1st February, 2017)
  7. #171
    Jan 2017
    Hi all
    Got a Zgemma h.2h box but only have sky cables.When I try to record on a different channel to what I'm watching it switches to that channel.Any advice would be welcome
  8. #172
    digicon's Avatar
    Quote Originally Posted by Simba9 View Post
    Hi all
    Zgemma H.2H is a Combo Satellite + DVB-C/T/T2 tuner used for Cable or Freeview HD, seeing as you only have Satellite you can only use the single satellite connection for recording from satellite.
    You could connect an aerial feed into the other DVB-C/T/T2 tuner and have all the Freeview HD stations so you could either record from satellite and watch freeview or vice versa
  9. #173
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Software Update: Fix ABM & add new channel picons
    • ABM Fixed (version 2.4 > 2.5 error)
    • Picons updated Aplustv, Cgtn, Home & Health +2, Shed +1 & Sky Cinema Valentine
  10. The Following 3 Users Say Thank You to martin035 For This Useful Post:
    Hadron (8th February, 2017), joe516 (9th March, 2017), tony_i (7th February, 2017)
  11. #174
    Dec 2013
    Just a quick thankyou to Martin for the image. Been using it for a while now with no problems, also put it on a few mates boxes and they have all been mightly impressed.
  12. #175
    The zip file on main page .. My box dosent recognise that as a flash image .. ive tried other images and the box detects them but not this one.. any ideas or any other link ?
  13. #176
    happy_highlander's Avatar
    Aug 2010
    Quote Originally Posted by Ramghariaboyz View Post
    Unzip it first
    Sent from my SM-G935F using Tapatalk
  14. #177
    Quote Originally Posted by happy_highlander View Post
    Unzip it first
    Unzipped prior to copying just the zgemma folder. dosent work unfortunately
    Tried a brand new USB drive.. still same..
  15. #178
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Hi, I've just tested the image on my own Zgemma H2S from downloading, unzipping, booting the zgemma with the USB in the rear USB port and pressing 'standby button' when 'USB' is displayed and can confirm that it does correctly flash.
    You are trying this on the H series Zgemma?
  16. #179
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor update 10 mar
    • New Picons added Motorsport, Monsters, cruise deals and others
    https://www.dropbox.com/s/1ae076aurpisv4c/picon.zip?dl=0
  17. The Following User Says Thank You to martin035 For This Useful Post:
    Hadron (11th March, 2017)
  18. #180
    Nov 2008
    Bo’ness, Scotland
    Dear Members,
    Thank you very much for a great reply, all explanations.
    Now I just got to flash the image on my zgemma star h1.
    Thanx again and keep improving.
    Cekerb
    Branko Cekovic
    (Cekrtb)
    BLUESMAN
