Zgemma H Series (H.s H.2s) Openatv5.3 Backup Image - Page 2
Page 2 of 14 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 210
  1. #16
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by smirnoff_rules View Post
    just setup and try it . its great really install on your pc and add this ipk to your box
    https://mega.nz/#!IIQ00DTA!3EcDDI8Gh...rZ4gcL4kuKFdT8
    sent u a pm too on setup
    always lerking PremierD
    Cheers for that, I'll give it a try and see how good it is on a H series, hopefully the box is quick enough. Notice dreamplex available via download plugins, is there any difference between your version and one in n the repos.
  2. #17
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by martin035 View Post
    might be better l dont know m8 best install the newest , l use on h1h and h2h and works fine m8 , cant bet a nowtv box tho
  3. #18
    happy_highlander's Avatar
    Aug 2010
    I use plex on all my recievers (and nowtv/firestick) and no offence smirnoff but the gigablue quad+and the xtrend et8000 both run plex better than nowtv there are no 5.1aac playback issues which effect the firestick version. @martin if you want to use the H series to stream from a remote plex server I'd suggest you set it to trandcode for movies but will need to change it to stream or direct play for music
  4. #19
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor Update 10/05
    Minor Update: Due to bugs with the Sky Q skin I have changed the default skin to the Kiddac's Orginal and best Sky HD box skin, also added his latest Virgin media look a like skin for any cable user who fancy trying this out.
    • Slyk HD 3.008 Skin added as Default skin
    • VSkin HD 1.003 Skin Added for Cable users
    Sky Q is still on the image and will be updated once chabs releases a new version.
    Vskin pictures
  5. The Following User Says Thank You to martin035 For This Useful Post:
    carbandit (20th May, 2016)
  6. #20
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor Update 22/05
    Minor Update: Chabs has released V1.3 of his SkyQ skin fixing the majority of problems/bugs, unfortunately the Media Player plugin still crashes with this skin, either use another Media player ie Plex or another Skin.
    • SkyQ Sikin updated to V1.3 and added as Default skin
    • VSkin HD Skin updated 1.007
  7. #21
    middots3's Avatar
    Feb 2009
    Middlesbrough
    I'm thinking about signing up for an IPTV service that is compatible with my h2s.
    I was wondering if there are any plugins or the like that can enable me to add my IPTV channels to a bouquet so i can access them from the EPG? And even retrieve what's on etc?
    As integrated as possible.
    Thanks.
  8. #22
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by middots3 View Post
    Thanks.
    IPTV List updater
    If using autobouquetsmaker ensure you set 'Keep all non-ABM bouquets' to 'Yes' in the ABM configue menu, else you'll lose you lists on an ABM scan
  9. #23
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor Update 2 Jun
    Minor Update: Removed Non Working BT HD channels
    • ABM updated
  10. The Following User Says Thank You to martin035 For This Useful Post:
    chetsp (3rd June, 2016)
  11. #24
    middots3's Avatar
    Feb 2009
    Middlesbrough
    Anyone know how to get kodi direct working properly? Trying to use castaway and no streams are loading, just stuck at 1%.
  12. #25
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    I seem to keep losing EPG after reboots.
    Any idea why?
    Yes, sounds like your epg.dat file is corrupt, do the following to fix
    1. FTP to your Zgemma's Hdd /media/hdd and delete the epg.dat file
    2. Menu-setup-service searching- ABM-Start Scan
    3. Menu-Setup-EPG-load/save – save EPG
    4. Press EPG and see if your EPG is populated then reboot and see if it's still been populated
  13. #26
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Castaway needs URL live resolver to work you'll most probably find that kodi direct hasn't be updated, how to update URL live resolver on kodi direct I don't know????
  14. #27
    middots3's Avatar
    Feb 2009
    Middlesbrough
    Ill have a fiddle around, castaway would be an ideal add on if I can get it working!
    Thanks for your help mate, really appreciated!
  15. The Following User Says Thank You to middots3 For This Useful Post:
    martin035 (3rd June, 2016)
  16. #28
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    If you getting it working let us know pse, I've got castaway on my Kodi machine and with what's happened to the BT channels and maybe the future, this addon could stop my Zgemma become a future door stop.
  17. #29
    Nov 2012
    Martin re the ABM update, any info on how I can edit my ABM to remove the BT HD channels? I have my vix image how I want it and dont fancy changing it but would like to adopt the ABM change you mention............thanks in advance
  18. #30
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by chetsp View Post
    1. Go to menu-plugins then press red to remove installed plugins find 'autobouquetmaker' and remove old version
    2. Go to menu-plugins then press green to install plugins find autoboubouquetsmaker' and install latest version
    3. Go to autoboubouquetsmaker in setting and select 'delete bouquets'
    4. Go to autoboubouquetsmaker in setting and select 'start scan'
    this will remove the none working BT HD channels
    Edit: Not required anymore ABM have updated there github to 2.1 which included an update feature;
    Menu-service searching-ABM-Update Config files
    Menu-serive searching-ABM-start scan
  19. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    chetsp (4th June, 2016), clapton64 (22nd August, 2016)
