Zgemma H Series (H.s H.2s) Openatv5.3 Backup Image - Page 3
Page 3 of 14 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 210
  1. #31
    May 2016
    Hi, I would like to try this build on my H2s I have Wooshbuild on my box at the mo, do I just flash this build over the top of Wooshbuild?
  2. #32
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by maxalman View Post
    Yes, backup any important cfg files first then flash the image it will over write woosh's build, then restore your important cfg files and setup the Zgemma following the instructions in post #1
  3. The Following User Says Thank You to martin035 For This Useful Post:
    maxalman (7th June, 2016)
  4. #33
    May 2016
    Quote Originally Posted by martin035 View Post
    Thank you for the advise, just flashed and all working good thanks.
  5. The Following User Says Thank You to maxalman For This Useful Post:
    martin035 (10th June, 2016)
  6. #34
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor Update 29 Jun
    Minor Update: New Channel picons
    • Picons added for the following new channels; viva, MTV 90s, Box hits, Box upfront, Ginxsportstv, CNN HD, Hill Song & Eman Channel
  7. #35
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor Update 9 July
    • Picons added for the following new channels; $ky Cinema Rebrand and eir sports Rebrand
  8. #36
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Sky The Open Picon
    I'm not going to rebuild a new image for 1 Permanent and 2 temp picons, so for those of you wanting a Sky The Open, Sky Star Trek and Pop Max Picons
    FTP the attached to /usr/share/enigma2/picon
  9. The Following User Says Thank You to martin035 For This Useful Post:
    satsmo (16th July, 2016)
  10. #37
    satsmo's Avatar
    Jun 2008
    Martin I speak to the ladies and gents at Openatv on regular basis, if you are going to release V5.4 you better let them know
    Thanks for assisting with your backup on the forum.
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
  11. The Following 2 Users Say Thank You to satsmo For This Useful Post:
    digicon (16th July, 2016), martin035 (16th July, 2016)
  12. #38
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor Update 28 July
    Minor Update: New Channel picons & Olympic Bouquet added
    • Picons added; from post#36, Harrypotter & Olympics channels
    • Olympic HD & SD channels 1-8 added to Sports Bouquet
  13. The Following User Says Thank You to martin035 For This Useful Post:
    maxalman (28th July, 2016)
  14. #39
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Sky Spies Picon
    For those of you wanting the $ky Spies picon;
  15. #40
    Hi this image work with h2h box?
  16. #41
    digicon's Avatar
    Yes it will but you will need to manually configure the second tuner on the H.2H
  17. The Following User Says Thank You to digicon For This Useful Post:
    martin035 (3rd August, 2016)
  18. #42
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    AutoBouquetsMaker names the BBC Olympic HD channels differently to SNP Picon names of the relevant channels, if you wish to have picons for these channels just unzip the attached and FTP to /usr/share/enigma2/picon
    Edit:Latest Backup Image has be updated to reflect this change
  19. The Following User Says Thank You to martin035 For This Useful Post:
    digicon (5th August, 2016)
  20. #43
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Minor Update 5 Aug
    Minor Update: As $ky Sports 5 ROI have the rights to broadcast the majority of 3 o'clock kick offs in Ireland instead of eir sports, I've added a custom bouquet with &ky Sports 5 ROI, $ky Sports 5 UK will not be showing any 3 o'clock kick offs. Also added missing/incorrectly named picons.
    • Custom Bouquet 'Sports ROI' added with $ky Sports 5 ROI
    • BBC Olympic HD 1-8, &ky Spies and xxxReal wives picons added
  21. The Following 3 Users Say Thank You to martin035 For This Useful Post:
    damiensk (6th August, 2016), digicon (5th August, 2016), holmesju (6th August, 2016)
  22. #44
    Top Poster + damiensk's Avatar
    manchester
    Hi Martin035,
    would i be able to delete the abm that i have on my box now and d/l the abm in the plugins, so that it gives me ss5 roi custom bouquet
    would just save me a re-flash and going through a set up again.
    thanks for all the hard work you put in for keeping these boxes upto date.
  23. The Following User Says Thank You to damiensk For This Useful Post:
    martin035 (6th August, 2016)
  24. #45
    Apr 2013
    Fantastic image mate runs like a dream on H.S, takes all the hassle out of setting up your own box. Keep up the good work
  25. The Following User Says Thank You to holmesju For This Useful Post:
