Thanks Martin035,
im going to give it a try and will post how i got on
No, unfortunately ABM haven't updated their Repo and I don't know if they will on this subject, so updating the ABM plugin won't give you $ky sports 5 ROI. You could try this modded file I've attached, it's not my file and hasn't been tested by me, it's meant to transfer $ky sports 5 ROI to you main sports bouquet and give you 2x $ky sports 5 one been the ROI one, however, it won't change the name unfortunately to $ky sports 5 ROI.
Use at your own risk and if it f***s up your box please don't give me any grief
Unzip then FTP the attached to /usr/lib/enigma2/python/plugins/systenplugins/autobouquetsmaker/custom then rescan ABM
Thanks to gmanpanthro for the file.
Edit: New Custommix file added to backup image dated 15th Aug
Thanks Martin035,
Hi Martin035,
it didnt work, unless im doing it wrong, i did do a rescan after.
Last edited by damiensk; 7th August, 2016 at 11:38 AM. Reason: no attachment shown
this is where i have put the file
Hi All
I have just installed skyq on my zgemma H2S but I'm now completely lost!! I don't have a clue what to do with the cams etc. My previous set up worked fine. I have tried to connect my box to firezilla but it wont connect. Any ideas?
You might want to read the forum rules on what can and cannot be discussed regarding 'cams'
Forum Rules
have just put your latest flash on a box, done a abm scan and ss5 roi, is now there as a bouquet,
sports ROI (tv), happy days
martin035 (8th August, 2016)
Hi, just got a new box today & tried to flash it with the above. It's a HS I've got but after unzipping the zgemma file from the dropbox link supplies in post when I put the freshly formatted 8gb stick in the box it just says boot then USB followed by Update then counts up to 100. Any suggestions would be greatly appreciated thanks
Have you done what martin said here " 5. Once ‘USB’ displayed on Box a quick press and release ‘standby’ button on box, this will then display ‘FLASH’ "
CrowsNest1970 (11th August, 2016), martin035 (12th August, 2016)
yep, worked wonders thank you maca flash looks amazing Martin035, keep up the good work & thanks
Just to add to Digicon's advice, the backup image does use SNP picons, so you will encounter the problems he describes if using the default picon set.
For a hassle free option, I advice just to install the latest backup image at post #1 this will give you SS5 ROI with an associated picon.
Edit: I have tested a new customix file and have added it to the backup imaged dated 15 Aug
digicon (12th August, 2016)
Updated Picons for Btsport 3 and My5 (channel5+24 Rebrand)
FTP the attached to /usr/share/enigma2/picon
digicon (13th August, 2016)
