hid3, the original Passat ABS Module was Part No SW: 3C0 614 095 S ... Component: ESP 440 C2 H015 0004.
I tried over 500 codes with no success! And yes, I had to rewire the plug to install the Jetta ABS Module MK60 1K0 907 379 AC. The Passat and Jetta ABS plugs were completely different!
I went through both the Jetta ABS wiring diagrams and the Passat B6 ABS wiring diagrams and marked down all of the ABS connections, pin locations, and wire colors respectively for both ABS plugs. Then I checked those pin numbers / wire colors with the actual Jetta / Passat ABS plugs (they were correct). Then I matched them up in Excel to know which wires to solder together with what. There were about 23 wires I believe.
It was a daunting task!
