VW Passat B7 2012
Long code ABS 1K0907379BS 1111111111111111111111111111111150001703161820
Hello really could do with your help thanks.
1. part # 1K0907379AN
2. 105 Golf V 2008 TDI
3. VIN: WVWZZZ1K9W049513
3.RHD
4.DIESEL 1.9
5.FWD
6.FRONT=280mm, REAR=255mm
7.No start/stop
8.TPSM yes i think theres a light on the dasch for it but dont think there are sensors in the wheels.
9.ESP OFF yes
10.No Hill Hold
Thanks in advance .
VW Passat B7 2012
Hello.
The coding was accepted but without the last bite (00).
This car have problems, the ABS unit is using 18 digit and the rest of the car is using 19 digit, it means that the
ABS installed donīt come from factory.
So i get several errors, like electrical problem in G251 sensor, basic setting not full or wrong , and wrong ABS unit installed.
The solution here is installing the correct ABS unit (1K0 907 37x AT) for a complete match.
Tanks for your time and help.
hi , i have a golf 6 , WVWZZZ1KZBW283940
can u help with long coding
Hello
please long coding for abs, lost during ecu change
Thank you
can You help me with long coding for ABS9.0 Skoda Fabia
6R0907379AR
VIN: TMBJS25J3D3133237
Thank you
please help with the following
MK60EC1
1K0 907 379 Ad
WVWZZZ1KZ9M362952
VW Golf V 1.9 TDI
thanks.
Hello lost long coding abs by taking out dash.
Now I know why saving.
Please help.
Caddy 1.6 Tdi 2013 LHD 55kw standard.
Ecu: 1K0 907 379 BK
Vin: WV1ZZZ2KZEX041369
Thanks.
hello guys, I need help with ABS jetta longcode
Jetta egine 2,5 5 cilinder 2009 AT
VIN 3VWHE61K69M151732
ESP MK60EC1 H35 0106
1K0 907 379 AD
Have a bottle ESP
TIRE PREESSURE
Left Hand Drive
Disc diameter 288
thanks advance
Hi I'm very new to this forum I've been registered a while but rarely use it can you plz help me with abs long coding thank you
WVWZZZ13Z9V028311
ESP MK60EC
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 60732 001 1048576
VCID: 76E35AB6C1E113F6BB-8022
Hi I have a scoda 01/2013 type5L VIN= TMBKF75L6C6031760
can anyone help with coding numer for ABS 1K0 907 379 BJ
ESP MK60EC1 H31 0121
I have lost coding it says Coding:00000000000000000000000000000000000000
thank you
Can you calculate me one ABS coding please ?
VIN: WVWZZZ1KZCW254424
1K0907379BJ
Golf VI
2.0 TDI
CFGB
Hello ,can someone calculate ABS coding please?
1. PART # 6R0 907 379 AA - ESP8.2i - H05 - 0003
2. Skoda Fabia 2011 - CAYA
3. VIN: TMBJS25J9B3206656
3.LHD
4.DIESEL 1.6 - MANUAL
5.FWD
6.FRONT=288mm, REAR=232 mm disk
10.No Hill Hold or TMP
Thanks in advance .
good day
VW JETTA 2010 2.5, 3VWAX7AJ0AM140870, 1K0907379AN, MK60EC1, H45 0107, IMP 011 , WSC01357. ENGINE CODE CBT
PLS HELP ME FOR LONG CODE
THANKS
PAUL
