Page 80 of 245 FirstFirst ... 3070757677787980818283848590130180 ... LastLast
Results 1,186 to 1,200 of 3668
  1. #1186
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by ibrasport View Post
    hi i want abs coding for skoda rapid 2013
    6R0614517BK
    VIN : TMBAT6NH3E4012091
    THX
    one of these is your Long coding :
    52292814092300FC4A0B14ED901A0080480400
    41292814892300FC820B14ED911A0040490400
    if find it useful please Press Thanks and Rep
  2. The Following User Says Thank You to vagva For This Useful Post:
    Drdiag (20th June, 2018)
  3. #1187
    I have replaced my old MK60EC1 for a new version that supports side assist. but cannot get the coding right.
    There is beer waiting for you when the module is coded !
    Specs :
    1. 1K0907379BS can be flashed to CC
    2. WVWGD7AJ9BW289978
    3. Golf 6 GTI 2011 USA model
    4. Left hand drive (LHD)
    5. CBFA engine with 200PS
    6. FWD
    7. No
    8. Direct TPMS with 3AA module
    9. Yes, ESP off button
    10. not needed with dsg i guess ?
    Old pump
    Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
       Component: ESP MK60EC1   H31 0106
       Revision: 00H31001
       Coding: 114B800C492A0003881401EB922100413D0800
       Shop #: WSC 01357 011 00200
       VCID: F8BCA6C04B5E928632-80AC
    No fault code found.
    NEW pump
    Can be flashed to CC if needed !
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Component: ESP MK60EC1   H46 0166
       Revision: 00H46001
       Coding: 0000000000000000000000000000000000000000
       Shop #: WSC 19427 133 00001
       VCID: 04444230879646643C-8050
    1 Fault Found:
    01042 - Control Module; Not Coded
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 73
                        Time Indication: 0
                        Date: 2018.06.07
                        Time: 20:11:04
                 Freeze Frame:
                        Count: 2
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 48896
                        Count: 65280
                        Count: 0
                        Count: 0
    Full recent auto scan ( pls ignore the errors ! )
    Thursday,07,June,2018,21:03:24:36185VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 18.2.0.3  HEX-NET CB: 0.4422.4
    Data version: 20180212 DS287.0
    www.Ross-Tech.com
    Dealer/Shop Name: 7
    VIN: WVWGD7AJ9BW289978   License Plate: 2-STK-64
    Mileage: 56850km-35324mi   Repair Order: 5F installed
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 25 2B 3C 42 44 46 47 52
              55 5F 62 65 69 72 A5
    VIN: WVWGD7AJ9BW289978   Mileage: 56850km-35324miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    14-Susp. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
       Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
       Component: 2.0l R4/4V TFSI     0040
       Revision: E3H25---    Serial number:
       Coding: 040301081C070960
       Shop #: WSC 00191 264 15243
       VCID: 78BC26C00B5E128420-802C
    10 Faults Found:
    002129 - Park/Neutral Switch Input Circuit
                   P0851 - 000 - Short to Ground - MIL ON
                 Freeze Frame:
                        Fault Status: 11100000
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56695 km
                        Time Indication: 0
                        Date: 2018.06.02
                        Time: 02:31:34
                 Freeze Frame:
                        RPM: 828 /min
                        Load: 25.9 %
                        Speed: 0.0 km/h
                        Temperature: 33.0°C
                        Temperature: 23.0°C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 13.970 V
    008568 - Bank 1; System Too Rich off Idle
                   P2178 - 000 -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56698 km
                        Time Indication: 0
                        Date: 2018.06.02
                        Time: 02:37:14
                 Freeze Frame:
                        RPM: 2464 /min
                        Load: 23.1 %
                        Speed: 32.0 km/h
                        Temperature: 79.0°C
                        Temperature: 24.0°C
                        Voltage: 13.970 V
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal - MIL ON
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56698 km
                        Time Indication: 0
                        Date: 2018.06.02
                        Time: 02:37:14
                 Freeze Frame:
                        RPM: 2464 /min
                        Load: 23.5 %
                        Speed: 33.0 km/h
                        Temperature: 79.0°C
                        Temperature: 24.0°C
                        Voltage: 13.970 V
    053271 - Please Check Fault Codes in Control Module for ABS Brakes
                   U1017 - 007 -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100111
                        Fault Priority: 0
                        Fault Frequency: 5
                        Reset counter: 255
                        Mileage: 56699 km
                        Time Indication: 0
                        Date: 2018.06.02
                        Time: 02:53:26
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 74.0°C
                        Temperature: 36.0°C
                        Voltage: 11.938 V
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 000 -  - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56699 km
                        Time Indication: 0
                        Date: 2018.06.02
                        Time: 02:55:27
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 74.0°C
                        Temperature: 37.0°C
                        Voltage: 11.938 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 000 - Supply Voltage - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56699 km
                        Time Indication: 0
                        Date: 2018.06.02
                        Time: 04:59:37
                 Freeze Frame:
                        RPM: 912 /min
                        Load: 28.6 %
                        Speed: 0.0 km/h
                        Temperature: 44.0°C
                        Temperature: 31.0°C
                        Voltage: 13.716 V
    049508 - No Communications with HVAC Control Module (J301)
                   U0164 - 000 -  - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56744 km
                        Time Indication: 0
                        Date: 2018.06.04
                        Time: 17:43:31
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 98.0°C
                        Temperature: 54.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.811 V
    049561 - Door Control Module - Driver's Door
                   U0199 - 000 - No Communications - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56854 km
                        Time Indication: 0
                        Date: 2018.06.07
                        Time: 19:57:53
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 76.0°C
                        Temperature: 49.0°C
                        Voltage: 11.938 V
    049472 - Body Control Module (Central Electric)
                   U0140 - 000 - No Communications - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56854 km
                        Time Indication: 0
                        Date: 2018.06.07
                        Time: 19:57:54
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 76.0°C
                        Temperature: 49.0°C
                        Voltage: 11.938 V
    049473 - Body Control Module (Central Electric 2)
                   U0141 - 000 - No Communications - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 56854 km
                        Time Indication: 0
                        Date: 2018.06.07
                        Time: 19:57:57
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 76.0°C
                        Temperature: 49.0°C
                        Voltage: 11.938 V
    Readiness: 0010 1100
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2716
       Revision: 05351113    Serial number: 00001105300653
       Coding: 0000020
       VCID: 197A0344D014EB8CFF-804C
       Revision: 00H46001
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 73
                        Time Indication: 0
                        Date: 2018.06.07
                        Time: 20:11:04
                 Freeze Frame:
                        Count: 2
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 48896
                        Count: 65280
                        Count: 0
                        Count: 0
    Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
       Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
       Component: VWKESSYPQ35GP 085 0802
       Revision: 00085000    Serial number: 0144798723
       Coding: 030C1C
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_KESSY_PQ35GP A01018
       ROD: EV_KESSY_PQ35GP.rod
       VCID: 3326D1EC9AB831DCD5-8066
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 1K8 907 044 AC    HW: 1K8 907 044 AC
       Component: Climatronic   H05 0304
       Revision: 00001K03
       Coding: 001801C002
       Shop #: WSC 00219 123 12345
       ASAM Dataset: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_VW36.rod
       VCID: 70AC1EE0AB2E4AC4E8-8024
    Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
       Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
       Component: BCM PQ35 H+   111 0148
       Revision: BL111001
       Coding: 67080AB7EC33E5C41058028970000B8443FD0011557D8D90E4806824A040
       Shop #: WSC 12345 123 12345
       VCID: 43C6812CC218815C45-8016
       Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 11031  26  0512
       Coding: 009FB5
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS 070712 05  54  0403
       Coding: 0730AD
       Subsystem 3 - Part No: 1K8 951 171
       Component: DWA-Sensor 00  001 0104
       Coding: 000000
       Subsystem 4 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Coding: 000000
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
       Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA 011 0480
       Revision: --------    Serial number: --------------
       Coding: 0031167111
       Shop #: WSC 00099 780 00200
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: EV_EPHVA2CVW364GP00_VW36.rod
       VCID: 3B36F9CCB2E8F99C0D-806E
    1 Fault Found:
    12658720 - Databus
              U1121 00 [008] - Missing Message
              [Steuergerät für elektrische Park-/Handbremse-J540 - mEPB_1 - kein Signal/keine Kommunikation]
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:11:05
    Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
       Part No SW: 3C0 907 376     HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0069
       Revision: 00000000    Serial number: 13020800690002
       Coding: 000180
       Shop #: WSC 00219 000 00000
       VCID: 668078B891EA947482-8032
    1 Fault Found:
    01316 - ABS Control Module
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Time Indication: 0
                        Date: 2018.06.07
                        Time: 20:32:40
                 Freeze Frame:
                        Bin. Bits: 00000000 00001000
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R02280F
       Coding: 00003031
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 393AE3C4B8D4CB8C1F-806C
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--0005LPJ600
       Crash sensor for side airbag: driver side:
       Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Fahr.V  H01 ----
       Serial number: 3572MSME4532205DZZZR
       Crash sensor for side airbag: front passenger side:
       Subsystem 3 - Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Beif.V  H01 ----
       Serial number: 3582MSME402E255DZZZ$
       Crash sensor for side airbag: rear: driver side:
       Component: S.Sens.Fahr.H  --- ----
       Serial number: 3512QSME7419077CZZZ
       Crash sensor for side airbag: rear: passenger side:
       Component: S.Sens.Beif.H  --- ----
       Serial number: 3522QSME5658097BZZZ0
       Crash sensor for front airbag: driver side:
       Component: F.Sens.Fahr  --- ----
       Serial number: 35527SME6C617526ZZZL
       Crash sensor for front airbag: front passenger side:
       Component: F.Sens.Beif  --- ----
       Serial number: 35627SME1C617526ZZZH
    Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
       Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
       Component: LENKS.MODUL   014 0140
       Revision: FF010040    Serial number: 20110329301698
       Coding: 1012100000
       ASAM Dataset: EV_SMLSNGVOLWSXS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DB237D4EC7C37AC73-8028
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H06 0010
       Coding: 830000
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 1K8 920 885 H    HW: 1K8 920 885 H
       Component: KOMBI         H04 1018
       Serial number: 00000000000000
       Coding: 171E230000
       Shop #: WSC 00020 999 12345
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
       VCID: 3C34FAD0B7E6FEA404-8068
    1 Fault Found:
    15361536 - Internal Control Module Memory Check Sum Error
              B2000 41 [009] - General checksum failure
              [ECU component protection eeprom defect]
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:11:05
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 21041600F13292
       Coding: 350002
       VCID: 7BB639CCFA68399C4D-802E
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H04 1018
       Coding: 000007
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
       ROD: EV_Immo_UDS_VDD_RM09.rod
       VCID: 6A980C888DF2B014A6-803E
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000077897004
       Coding: 4900000000000000
       ASAM Dataset: EV_ELVMarquMPVW36X A01001
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E10C098719A1C34BA-807A
    Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
       Part No SW: 5Q0 907 686 B    HW: 5Q0 907 686 B
       Component: HRE_Master    H11 0071
       Serial number: 0367435529
       Coding: 02012102
       Shop #: WSC 00046 123 12345
       ASAM Dataset: EV_HREntryHella 001028
       ROD: EV_HREntryHella_VW27.rod
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 5Q0 907 685 B    HW: 5Q0 907 685 B
       Component: HRE_Slave  H11 0071
       Serial number: 0366681323
       Coding: 020121
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
       Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
       Component: Tuer-SG         009 2120
       Coding: 0005366
       Shop #: WSC 80093 222 69422
       VCID: 3228D4E8ADA238D4DE-8066
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 183    3201
       Revision: 00H20000
       VCID: 3424D2F057B636E4CC-8060
    Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
       Part No SW: 5K0 035 456     HW: 5K0 035 456
       Component: KonzernAmp 8K H06 0340
       Revision: --------    Serial number: BP218109117144
       ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
       ROD: EV_AudioVerst8KanalBNO1.rod
       VCID: 679E75BC9EE08D7CB9-8032
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
       Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
       Component: Tuer-SG         009 2151
       Coding: 0005622
       Shop #: WSC 46651 001 104857
       VCID: 3522EFF45CCC2FECFB-8060
    Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
       Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
       Component: AFS-Steuergeraet    0148
       Revision: 00H04000    Serial number:
       Coding: 1477724
       Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0004
       Coding: 00000022
    Address 5F: Information Electr. (J794)       Labels:* None
       Part No SW: 5L0 035 680 E    HW: 5L0 035 680 E
       Component: MU-S-ND-ER    X72 X346
       Serial number: SKZAZ2R1995438
       Coding: 03130601AA00000011111105C0880A021F0807C400210100CF
       Shop #: WSC 12345 102 209715
       ASAM Dataset: EV_MUStd4CTSAT 001022
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 2C14CA9047866E2494-8078
    7 Faults Found:
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:38:32
                        Voltage terminal 30: 11.6 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    1555 - Check Software Version Management
              B201A 00 [009] -  -
              [Check software version management]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:38:32
                        Status_Software_Version_Management-module_name:
    13697024 - Component Protection
              U1100 00 [009] - No Basic Setting
              [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:38:32
    15360512 - Component Protection
              U1101 00 [009] - Active
              [Anti-theft protection - component protection active (0xEA6200)]
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:38:32
    0011 - Digital Radio Antenna
              B1103 13 [009] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:59:05
                        Voltage terminal 30: 13.1 V
                        Status of digital radio antenna 1-Antenna current: 0 mA
                        Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                        Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
    1552 - Expanded Bus Activity Active
              U1104 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:38:32
    1637 - Interface for External Media
              U11B8 00 [009] - No Communications
              [USB - communication error]
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 20:38:33
                        Interface for external media: status-Status: Open circuit
    Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
       Part No SW: 5K0 959 703 D    HW: 5K0 959 703 D
       Component: Tuer-SG         007 2101
       Coding: 0001232
       Shop #: WSC 01357 011 1012552
    Address 65: Tire Pressure (J502)       Labels: 3AA-907-273.clb
       Part No SW: 3AA 907 273 H    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0012
       Serial number: 30000000035684
       ASAM Dataset: EV_RDKBERU30 006001
       ROD: EV_RDKBERU30_006_VW36.rod
    4 Faults Found:
    8397058 - Front Left TPMS Sensor
              C1050 31 [009] - No Signal
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 136
                        Mileage: 49670 km
                        Date: 2017.11.29
                        Time: 19:11:05
                        Vehicle speed: 90 km/h
                        Outside air temperature: 2.0 °C
                        Reception level antenna 1: 620 mV
                        Offset level antenna 1: 300 mV
    8397314 - Front Right TPMS Sensor
              C1051 31 [009] - No Signal
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 136
                        Mileage: 49670 km
                        Date: 2017.11.29
                        Time: 19:11:05
                        Reception level antenna 1: 640 mV
    8397570 - Rear Left TPMS Sensor
              C1052 31 [009] - No Signal
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 136
                        Mileage: 49670 km
                        Date: 2017.11.29
                        Time: 19:11:05
                        Reception level antenna 1: 630 mV
    8397826 - Rear Right TPMS Sensor
              C1053 31 [009] - No Signal
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 136
                        Mileage: 49670 km
                        Date: 2017.11.29
                        Time: 19:11:05
                        Reception level antenna 1: 650 mV
    Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Component: Anhaenger     H09 0100
       Revision: 3A001001    Serial number: 00000147679016
       Coding: 010D000202000000
       VCID: 302CDEE063AE0AC4A8-8064
    Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
       Part No SW: 5K0 959 704 D    HW: 5K0 959 704 D
       Coding: 0001232
       Shop #: WSC 00000 000 00000
       VCID: 3620E8F841CA24F4F2-8062
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
       Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
       Component: MFK_Gen1      H08 0300
       Serial number: 0185616805
       Coding: 010001000102020F0200040001010000
       Shop #: WSC 06745 128 28888
       ASAM Dataset: EV_47X 001639
       ROD: EV_47X.rod
    3 Faults Found:
    2621440 - Databus
              U1121 00 [009] - Missing Message
              [ERR_CAN_PSD_01_TIMEOUT]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 21:02:56
    2686976 - Databus
              [ERR_CAN_PSD_02_TIMEOUT]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 21:02:56
    4456448 - Databus
              U1123 00 [009] - Received Error Message
              [ERR_CAN_CAN_MBREMSE_5_ERROR]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 73
                        Mileage: 56854 km
                        Date: 2018.06.07
                        Time: 21:02:56
    End----------(Elapsed Time: 01:51, VBatt start/end: 13.7V/13.7V)-----------
  4. #1188
    Jul 2016
    Vilnius
    Picking this challenge up.
    * MK100
  5. #1189
    Jun 2018
    I would also be grateful if you could give me the long code as well vin WV1ZZZ2KZDX099287
    MK60EC1
    Thanks.
  6. #1190
    Jun 2018
    i have the same problem.
    Could if possible have the long code for a 2013 vw caddy MAXI
    MK60EC1.
    1K097379BK
    Cayd
    RHD
    Thanks.
  7. #1191
    Jun 2018
    Default please help!!
    Can you help me with my car ABS long Coding.
    Seat altea 2.0tdi dsg (2013) Diesel, RHD,fwd,
    Esp center control
    Vin: vsszzz5PzDR004190
  8. #1192
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Bernardcaddy View Post
    MK60EC1
    Thanks.
    you should explain more
    car model?
    car type ?
  9. #1193
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Royski31 View Post
    Esp center control
    Here is your Long Coding :
    213F4012092200FE840C02ED90190041350400
  10. #1194
    razvanrms's Avatar
    Sep 2015
    romania
    Hi! Can you help me with my car , ABS Long Coding ?
    Vw Caddy 1.9 TDI BLS 4MOTION, LHD, 2010 .
    VIN WV1ZZZ2KZAX113154
    ESP MK60EC1 H45 0103 , WSC 35110
    2K0 907 379 D
    FULL SCAN HERE
    Thanks in advance !
  11. #1195
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by razvanrms View Post
    2K0 907 379 D
    FULL SCAN HERE
    Thanks in advance !
    Hi here is your Long Coding :
    423C400D092303FD420C02E9901DC041300000
    • if find it useful please Press Thanks and Rep
  12. The Following User Says Thank You to vagva For This Useful Post:
    razvanrms (26th June, 2018)
  13. #1196
    Jul 2016
    Vilnius
    That Caddy-only module is very rare and different. I highly doubt that given coding will get accepted; in fact I'm 99.9% sure it will be rejected.
    * MK100
  14. #1197
    world
    Hello there, i need the long coding for;
    VW JETTA
    1,6 TDI
    WVWZZZ16ZEM048888
    LHD
    MK60EC1
    1K0907379BM
    ABS SW: 0164
    Engine: CAYC
    Automatic FWD
    77kw
    TPM not sure
    START-STOP NO
    EU vehicle
  15. #1198
    razvanrms's Avatar
    Sep 2015
    romania
    Quote Originally Posted by vagva View Post
    Thanks bro , but not working ... i solved problem at my local dealer !
  16. #1199
    razvanrms's Avatar
    Sep 2015
    romania
    Quote Originally Posted by hid3 View Post
    Solved , thanks !
  17. #1200
    Jul 2016
    Vilnius
    Any chance you could share the new coding?
    Thanks.
    * MK100
