emrahdamar (25th December, 2018), Ylwgtr (10th January, 2019)
I bet you know what to do in case you need the only one, working code
* MK100;
Hi mate. I´m looking for coding for this car:
Skoda octavia 1.9 tdi BXE 105hp year 2009 - RHD - FWD
TMBCS61Z38C013066
abs ate 1k0907379ad
thanks in advance
Last edited by alclot; 2nd January, 2019 at 06:49 PM. Reason: I forgot abs reference
you did not write what is the abs pump model
Hi.
I need Abs coding for Vw Touran 2013my 2,0tdi CFHC, Abs is ESP MK60EC1 H31 0152, 1K0 907 379 BL
Vin: WVGZZZ1TZDW051525
Thank you for any help
HI NEED LONG CODING FOR ABS MK60C1
PART NO: 1K0907379BD
VIN: TMBBE73T6B9053499
SKODA SUPERB 2011
RIGHT HAND DRIVE
2.0TDI
FWD
NO STOP STERT
HAS TPMS BUT DONT KNOW IF THE SENSORS ARE IN THE WHEELS
ESP OFF SWITCH INSTALED
NO HILD HOLD SYSTEM
THANKS
HI NEED LONG CODING FOR ABS MK60EC1
1K0907379AN
VIN: WVWZZZ1KZAW102606
golf 6 2009
LEFT HAND DRIVE
2.0TDI
THANK YOU
Hi, I need Skoda YETI ABS : 1K0 907 379 BJ VIN: TMBJT65L4F6029475 Left hand drive 1.6 CAYC thank you
Hi , please help me with coding Tiguan abs 5N0 614 109 BD 2 weel drive ,no hill ,no start stop WVGAV3AX9EW057199
Thanks are welcome !
Please delete, duplicate!
Hi there!
Would it be possible to obtain the long coding for the ABS module, for a 2011 RHD Seat Ibiza Estate DSG 1.2TSI? Here is a copy of the AutoScan and Label in the boot:
Chassis Type: 6J (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZBR189095
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 AE HW: 03F 906 070 P
Component: SIMOS10.22H03 9970
Revision: --H03--- Serial number:
Coding: 002500D6202400080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070AE 004010
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 65CACA57640DA36971-8030
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 Q HW: 0AM 927 769 D
Component: GSG DSG AG7 411 9060
Revision: 00041014 Serial number: TFK01104290166
Coding: 0000020
Shop #: WSC 00555 002 1048576
VCID: 3776501F4521E1F913-5140
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 0004FBC3976F6641E2-8054
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0320
Revision: 00 25 08 Serial number: 0000001661705-
VCID: 244C9753E7B79A61A6-8070
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0394 130110684
Coding: 24880BE888612500923000007E0B1CC800C0400F608C000020 0000000000
Shop #: WSC 64564 324 38760
VCID: 428031CBDDE3B451B4-8016
Subsystem 1 - Part No SW: 6R0 959 802 N HW: 6R0 959 802 N Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 3110
Serial number: --------------------
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 Q HW: 6R0 959 801 Q Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 3110
Coding: 020000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Coding: 000000
Subsystem 5 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 6 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3121
Coding: 000000
Subsystem 7 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3121
Coding: 000000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA0D H09 0020
Revision: -------- Serial number: 003GX00LX3S8
Coding: 003044
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4A9019EBEDD36C117C-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB405V0HGJ6J9OL
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB405D0HM7EI1QX
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 902 HW: 6J0 920 902
Component: KOMBI H05 0404
Serial number: 00000000000000
Coding: 410A00
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 66C8CD5B990BA87178-8032
1 Fault Found:
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 322300
VCID: 70E4AB03A3CF76C112-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0404
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6AD0B96B8D138C115C-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10111
Shop #: WSC 06402
VCID: 2F66687FEA7129394B-807A
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70E4AB0363CF76C112-8024
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J2 035 153 G HW: 6J2 035 153 G
Component: Radio H14 0204
Revision: R0000000 Serial number: SEZAZ2L1947755
Coding: 0505040002
VCID: 2A50796B45934C119C-807E
End-------------------------(Elapsed Time: 03:20)--------------------------
The car does not have any traction control or ESP button at all. Hill start assist would be cool if possible to enable.
Many thanks!
Hi to all!!!
Need help asap long coding for
golf 6 1.6 TDI CAYC 2010year
ESPMK60EC1
1K0907379 BJ
WVWZZZ1KZAW261407
Left hand drive
Any help would be much appreciated.
Thanks in advance
Hello there...
im searching for long code for abs module vin
WAUZZZ8U2ER100139
car is 2014 Audi Q3 rhd
