Anyone help me the long code for abs?
Vin: WVWZZZ1KZ9W540422
Thank you.
Anyone help? This car is a golf 6 1,4 tsi, LHD the wheel is 15''.
The long code generator not work.
Thank you.
Hi - I've a 2011 Audi TTRS and using VCDS have been trying to add indirect TPMS and Hill Hold. Researching I've been told the ABS Module for the TTRS (and RS3) cannot be coded by VCDS and requires Audi SVM. Just wanted to check whether there are ways around this?
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 HW: 8J0 614 517 C
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0608151
Shop #: WSC 01236 785 00200
VCID: 69D2A94C4055780CAF-803C
Many thanks
Fom what I have head, the ABS modules on Audi TT(RS) require an additional module specifically for TPMS functionality. Are you absolutely sure this is not the case?
* MK100;
There are conflicting posts on this but you may be correct. It seems the ABS module on the TTRS has no long coding available so only Audi can code the module using SVM. But perhaps they just change the module I am not sure. I was checking whether you were able to provide an updated short code to try with the TPMS and hill start coded. Thanks.
As fo Hill-Hold: check the adaptations channels. Hill hold hould be enabled somewhere there. I emember I enabled it without changing the coding.
Regarding TPMS, I will check.
* MK100;
Thanks - using my original ABS short code of 0608151 I could not enable hill hold in adaptions. I seen a post that adding 2048 to your code opened up the adaptation this seems to have worked for me as in adaptions now with new code of 0610199 I could choose various hill hold settings. Just need to get a working code for TPMS that works. Cheers!
Hi There, I really need help with ABS long coding.
I have abs long code helper v2 but just cant get my module to accept any codes i generate. ABS lost all coding, just 0000000000000000 now.
Thanking you in advance
1. ABS module part number 1KO 907 379AJ / ESP MK60EC1 H30 0107
2. Exact model of the car AUDI A3, 1.8TSI SPORTSBACK 7SPD AUTO
3. Year of the car 2010
4. VIN WAUZZZ8P1AA143101
5. Left hand drive or right hand drive model RHD
6. Engine type (gas or diesel) and displacement. 1.8I PETROL
7. 4Motion/4WD version or FWD
8. Provide front brake disc diameter, if known. PR number 1ZE
9. Is there any start/stop ("eco"/"bluemotion"/etc) system installed in the car? NO
10. Is there any kind of TPMS? If yes, then what kind of TPMS - indirect ABS based (no sensors in each wheel) or direct system which uses sensors inside the wheels? NO
11. Does the car have ASR/ESP off buttons? YES
12. "Hill hold" function. Does the car have one? Do you want it to be activated? YES
* MK100;
hi, my car is AUDI A3
VIN WAUZZZ8PXAB006359
YEAR 2010
2.0 TDI
LHD
ESP BUTTON YES
TMPS ?
NOT 4X4
REGARDS
Please help AUDI A3 1.6TDI AN2011 - ESP MK60EC1 - 1K0 907 379 JB
Thank you
