Your abs long code: 113b201c092400ff880e04ea901d0042300000
smokinjoe (5th April, 2018)
Hello .
Needs the correct coding for pump 1k0907379BS. My previous coding on the 1k0907379BD pump is 113BC01C092A0003880E03EA901D0041360C00. At the moment I have all the sensors and the encoded pump 1k0907379BS 113BC01C092A0003880E03EA901D0040A50D5089 encoded.
There were errors with me
03842 - Rear right speed sensor; incorrect signal
03841 - Rear left speed sensor; incorrect signal
02849 - Assistant track control (J769)
03075 - Controller for automatic parking remote control (J791)
My vehicle.
Abs 1k0907379BS
LHD
HHD
Vin TMBTSC1Z1B2089364
1.9 TDI
Manual 6 Speed ( Original factory 5 Speed )
FWD
Shield front 312
Back shield 288
Is it possible to receive coding with and without recuperation
Without Start Stop
Model year 2011 B
Hi!
Jak sie masz?
Forum language is English only.
Try this coding:
113BC01C092A0003880E03EA901D0040A50C0089
This is without start/stop (looks like your car does not have one anyway). So recode to this code, cycle the ignition, clear the fault codes.
If there are still remaining fault codes, please post them here.
* MK100;
Ok, I corrected
I do not have a start stop. But I added an alternator for recuperation and a battery cable
From what is known, Start Stop and Recuperation require an Alternator and Cable from the battery. I can not start Recuperation probably because it is not encoded in the ABS pump
Thank you for providing the coding. I'll check them.
Start/stop system requires a special battery regulation module.
Anyways, firstly let's make a valid coding so that you won't have any fault codes, later on I will make 2 codings for you, one w/start/stop, another without
* MK100;
Hello.
Your coding tip was very good. I had an error in byte 20 and corrected from 89 to 73 and it works. I do not have any mistakes. HHC in channel 53 says that too early and HHC does not work but there are no errors. From what I learned, I have to do adaptations of the position sensor.
I am asking for coding with START / STOP and thank you very much for your help. I will write about the progress of work.
I have mounted and coded
START / STOP of the special battery adjustment module for the adress 061 system
Today, new generation sensors for PLA 2.0 will come to me.
This one is for new gen sensors:
113BC01C092A0003880E03EA901D0040A50C5089
* MK100;
Hello can someone help me with my lost long coding please?.
Wvwzzz1kz9w041777
So08LJL
