* MK100;
Let's not give up!!
try this:
114BC012492300FC881303E492210041310000
if not, then this:
114BC00F492300FC881303E492210041310000
You don't need any pin or login for coding, just go to Long Coding. Then if the module accepts the coding, you will need to use Login to adapt sensors. But before that let's figure out the correct coding first!
* MK100;
detay07 (17th August, 2022)
Really strange.. Now you need to go brute force:
114B6012492300FC881306E492210041310000
114B600C492300FC881306E492210041310000
114B600D492300FC881306E492210041310000
114B600F492300FC881306E492210041310000
Also, this car does NOT have ALL-wheel-drive (4WD), has it?
* MK100;
poki123 (15th September, 2016)
Also, two important things:
1. Make sure your battery voltage is sufficient (12.2 V at least)
2. Make you you're entering a non zero WSC/Importer/Equipment numbers before clicking "Do It" when doing the coding.
* MK100;
One more coding which may work:
1150C00F492300FC881303E492210041390800
* MK100;
Many thanks for lot of coding strings. Today I back home. Tomorrow morning I'll test all of codes and immediately give you a feedback.
First of all before coding or flashing always I connect external charger to the car's instalation so voltage has100% properly value about 13,2 V.
I can't test it now because I left my workshop, I was afraid of leave connected VCDS and key in ON position in car with Teamviewer to operate all of it
impossible is nothing...
quattro?
I don think so. I must look under car and check it. 99% is no all wheel drive (quattro)
Yeah, sure, leaving with ignition ON is a bad idea.
Check and report back.
Start from the last coding I posted and go up. Make sure the WSC, Importer and other fields are not zeroes too!
* MK100;
I have tested last five coding and every one is not correct
This car is for sure no AWD is front wheel drive.
Which part in car decides that codding pass or not? gateway, immo, ecu? abs module?
It's thre ABS module but it does checks against some other, e.g. ECU, instrument cluster.
Let me think a bit on this and I'll probably provide some more codings...
* MK100;
Alright, please check the VIN number in CAN Gateway just to be sure.
A few more codings, but honestly at this stage I'm more guessing rather than using some logic:
1450C00F492300FC881303E492210041390800
7450C00F492300FC881303E492210041390800
1150C00F492300FC881303E492210041390000
1150C00F492300FC881303E492210041380000
1150C00F492300FC881303E492210041310000
1150C00F492300FC881303E492210041300000
1150C00F492300FC881303E492210040390800
1150C00F492300FC881303E492210042390800
1150C00F492300FC881303E492210051390800
1150C00F492300FC881303E492210050390800
114BC00F492300FC881303E492210041390800
1148C00F492300FC881303E492210041390800
* MK100;
no success
but take a look on option 1KS is code of rear breke disks 232mm x 9
what does mean first byte in codding 11 , 14 , 74
I can't find VIN in gateway (19).
This is what I'm seeing in autoscan, Instruments module:
1 Fault Found
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 124756 km
Time Indication: 0
Date: 2014.06.16
Time: 00:00:01
Quite possible it might be preventing the ABS from accepting coding. What's wrong with that instrument cluster? Any ideas on fixing the fault code?
Yes, I'm aware of 1KS PR code. In fact, even with wrong brake disc diameters set, it should accept the coding, just your ESP would not be so efficient as it could be.
11 means Standart LHD
14 Means GTI/GTD/RS/S LHD model
74 is being used for Scirocco LHD model so I just gave it a try.
Honestly, I'm out of ideas. Maybe someone else withh chime in.
* MK100;
