Page 84 of 245 FirstFirst ... 3474798081828384858687888994134184 ... LastLast
Results 1,246 to 1,260 of 3668
  1. #1246
    Aug 2018
    Hi can you please help me with the long code for my vw golf v variant.
    1. Vw golf variant 2009
    2. Engine BWA 2.0 tfsi
    3. 6 speed DSg
    4. RHD
    5. 17 inch wheel size
    6. Standard suspension
    7. TPMS
    8. ESP on/off button (mk60 ec1)
    9. 288 mm disks
    10. Vin WVWZZZ1KZ9M260320
  2. #1247
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Bradwyn View Post
    3. 6 speed DSg
    4. RHD
    7. TPMS
    9. 288 mm disks
    One of these going to be your long coding :
    113B400D092880FA880E02E690190142350800
    133B200D092800FAC80E04E690190091310000
    if you find My Help is Useful , please press Thanks and Rep
  3. The Following User Says Thank You to vagva For This Useful Post:
    Bradwyn (6th August, 2018)
  4. #1248
    May 2013
    hi can you help long code audi a3 please
    WAUZZZ8P1AA053401
    ESP MK60EC1 H45 0107
    1KO 907 379 AN
  5. #1249
    Nov 2017
    Hi!
    Can you help me with a Long code for Golf VI ABS/ESP?
    The original ABS module has died. The replacement module : 1K0 907 379 AD
    Left hand drive. 280/253mm disks. No hillhold assistant.
    Here are the specs:
    THX in advance.
  6. #1250
    Aug 2018
    I need help please.
    have a VW Eos
    WVWZZZ1FZ8V018411
    Address 03: Brake electronics Label file: DRV \ 1K0-907-379-MK60-F.lbl
    Part Number SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0004834
    Operating No .: WSC 00020 790 00000
    VCID: 73B4DCDA5BA2BC215E-8026
    LHD
    BWA engine 2.0l TFSI 200 HP
    345 front brake 282 rear
    manual switch
    no PLA
    ESP off button
    Tire pressure via ABS (no extra control unit)
    convert to:
    1K0907379CC H46 0175
    would like to code once with XDS and hill hold and once without.
    since there are CC 20byte I do not know what I have to write last byte.
    I tried it myself with the coding maybe someone can correct
    543B8008092380022A0F01E5901A01423D000000 (??)
  7. #1251
    Hi !
    I've retrofited my jetta mk5 from ASR to ESP, and now I can't calculate right long coding.
    1K0 907 379 CC
    Jetta 1.4 CAXA WVWZZZ1KZ8M158208, 288mm front/256mm rear disk, NO 4x4, LHD, no PLA
    ESP off button
    I've tried a lot of calculators without succes,
  8. #1252
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    CAN SOMEONE HELP CODIG SEAT LEON 2006 1P HERE IS SCAN COMPLET OF CAR
  9. #1253
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    SOLVED THANKS FOR
  10. #1254
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by MICKEYMAC1 View Post
    WAUZZZ8P1AA053401
    1KO 907 379 AN
    Here is your Long Coding :
    11424012092700FD880F02E4901A004139080053401
    Try & report and click "THANKS" and "REPUTATION" buttons
  11. #1255
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Peron View Post
    Hi!
    Here are the specs:
    THX in advance.
    try one of these long coding please :
    113B400D092480FE881102E490190142350800
    133B200D092400FEC81104E490190091310000
  12. #1256
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by DuffY666 View Post
    I need help please.
    have a VW Eos
    WVWZZZ1FZ8V018411
    Revision: 00H11001
    Coding: 0004834
    LHD
    manual switch
    no PLA
    ESP off button
    convert to:
    one of these are your long coding :
    563B6008092300026A0F06E5901A0092350000
  13. #1257
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by gsd.md View Post
    Hi !
    1K0 907 379 CC
    ESP off button
    Here is your long coding :
    A13B20F809270002850D04E49021004121100
  14. The Following User Says Thank You to vagva For This Useful Post:
    gsd.md (16th August, 2018)
  15. #1258
    tsistvan's Avatar
    HUNGARY
    Default Help SCIROCCO ABS
    Hi, I need help for long coding ABS 2014 SCIROCCO 2.0 tdi DSG THANK YOU !!!!!!!
    1, SCIROCCO
    2, 2.0 L CFHC
    3, DSG
    4, LHD
    5, 18 " Tyre
    6, Standard suspension
    7, TPMS
    8, ESP button
    9, 288 mm Disc
    10, VIN in log files
  16. #1259
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by tsistvan View Post
    1, SCIROCCO
    2, 2.0 L CFHC
    3, DSG
    4, LHD
    5, 18 " Tyre
    7, TPMS
    8, ESP button
    9, 288 mm Disc
    Here is your Long coding :
    763B60F5492300FE6E1406E4921C0082A1000053
  17. The Following User Says Thank You to vagva For This Useful Post:
    tsistvan (16th August, 2018)
  18. #1260
    Quote Originally Posted by vagva View Post
    Thank you, but one simbol is missing probably. Could you send coding again foe my MK5 Jetta?
    1K0 907 379 CC
    ESP off button
