dmp (10th September, 2018)
Help LONG CODING ABS 8.2i H040005 Seat Ibiza 1.6 BTS 2009r.
VSSZZZ6JZ9R139933
ABS NR: 6R0907379H
dmp (11th September, 2018)
Hi, could you help me with a long code for a 2011 VW Golf 2.5l Auto. No communication with old module. Vin# wvwbb7ajxbw065148
Thank you.
dmka (12th September, 2018)
Thanks, I will give it a try.
Hi!!
Heed longcoding.
Audi a3 1.9tdi LHD
ABS:1K0907379CD MK60EC1
WAUZZZ8P99A001302
cido123 (14th September, 2018)
Hello i need help with coding A3 S-line 2.0tdi RHD WAUZZZ8P0CA167988 Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ Component: ESP MK60EC1 H31 0121
Revision: 00H31001 i try long coding 1642001209280001681400EC90210000000000 for RS , long coding 1342001209280001681400EC90210000000000 for standart , but not work .
NO PASS
hi there. please i need if possible long coding for vw scirocco. removed cluster fitted another cluster to see if faulty dash handbreak light will go off. refitted original cluster and lost long coding. silly me forget to log abs coding before removing cluster. could you please help dear friend.
this is original log.
vin nr. wvwzzz13z9v037189 i also sent pr number. thanks.
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 CE HW: 1K0 907 379 AE
Component and/or Version: ESP MK60EC1 H35 0120
Software Coding: 000000000000000000000000000000000000
Work Shop Code: WSC 30140 001 1048576
VCID: 77FD8DEAC68F76FEA0-8022
3 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 151489 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 12288
Count: 279
Count: 43008
Count: 0
Count: 0
Count: 2048
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 151489 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 12288
Count: 295
Count: 43008
Count: 0
Count: 0
Count: 2048
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 151489 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 2
Count: 12288
Count: 270
Count: 43008
Count: 0
Count: 0
Count: 2048
this is a similar other scirocco coding i got. hope it will help alittle.
763B80F5492480FF6E1001E592210181350800
pr numbers. thanks.
wvwzzz13z9v037189
137 9w3
SCIROCCO 2,0 SPORT
147 KW TSID6F
CAW LQZ
LD1X L---L--- TL
BOA C9T G1A HV3 J1L D2L
VOA 1AT 1G6 2FP 5RV 5SJ
3V1 QG2 8AE 8GU
1LJ 3FG 0GV
4UF 4X3 4R4 4K3 N1A
8RM 2JC E0A
1D0 A8I 8BK USA 1N3 3PE 4A3 8N3
THANKS. HOPE THIS HELPS. KEEP WELL
