Page 53 of 245 FirstFirst ... 343484950515253545556575863103153 ... LastLast
Results 781 to 795 of 3668
  1. #781
    Apr 2017
    hey pls help me coding abs A3
    Thursday,07,September,2017,14:36:34:49450
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 16.8.0.3
    Data version: 20160803 DS255
    www.Ross-Tech.com
    VIN: WAUZZZ8P79A056086 License Plate:
    Mileage: 175800km-109237mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
    VIN: WAUZZZ8P79A056086 Mileage: 175800km-109237miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 EA HW: 03L 906 022 BQ
    Component: R4 2,0L EDC G000SG 3612
    Revision: 13H01--- Serial number: AUX7Z0H9FN60DZ
    Coding: 0000172
    Shop #: WSC 18432 807 674438
    VCID: 68DFD2C65BB2F10208-803C
    1 Fault Found:
    049493 - No Communication with Instrument Cluster
    U0155 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 175776 km
    Time Indication: 0
    Date: 2017.09.09
    Time: 00:07:49
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Temperature: 31.5°C
    Voltage: 12.54 V
    Bin. Bits: 00000000
    Torque: 126.0 Nm
    Temperature: 54.0°C
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 80093 222 69422
    VCID: 75E18BB2DC001CEA83-8020
    2 Faults Found:
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 187
    Mileage: 175803 km
    Time Indication: 0
    Date: 2017.09.07
    Time: 14:31:36
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 4096
    Count: 320
    Count: 45056
    Count: 65280
    Count: 0
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 187
    Time Indication: 0
    Date: 2017.09.07
    Time: 14:31:41
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 4096
    Count: 195
    Count: 44800
    Count: 65280
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
    Component: KlimavollautomatH09 0100
    Revision: 000490 Serial number: 8P0820043BG
    Shop #: WSC 00000 000 00000
    VCID: 72EBB0AE6D6E0BD2A6-8026
    3 Faults Found:
    01232 - A/C Compressor Regulator Valve (N280)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 8
    Reset counter: 202
    Mileage: 177608 km
    Time Indication: 0
    Date: 2017.04.24
    Time: 18:20:56
    Freeze Frame:
    Load: 50.0 %
    Current: 0.000 A
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 178042 km
    Time Indication: 0
    Date: 2017.04.26
    Time: 20:18:55
    Freeze Frame:
    Temperature: 35.0°C
    Voltage: 13.50 V
    RPM: 750 /min
    Load: 0.0 %
    Load: 0.0 %
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 224
    Mileage: 178682 km
    Time Indication: 0
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000008990087
    Coding: 11A82F8190141380EF00001C0000000000094E056401040100 A800000000
    Shop #: WSC 06314 000 08192
    VCID: 489F32463B72D10228-801C
    Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    2 Faults Found:
    00987 - Lamp for Brake Light; Left (M9)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 187
    Mileage: 63552 km
    Time Indication: 0
    Date: 2015.10.10
    Time: 00:11:00
    Freeze Frame:
    ON
    Voltage: 12.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 175776 km
    Time Indication: 0
    Date: 2017.09.09
    Time: 00:07:00
    Freeze Frame:
    ON
    Voltage: 12.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142383038303030364A55304C38503053
    Shop #: WSC 06314 000 00000
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 49993742E878280A37-801C
    Crash sensor for side airbag: driver side:
    Serial number: 3572DRB400007C48B19
    Crash sensor for side airbag: front passenger side:
    Serial number: 3582DRB400007C1D49E4
    Crash sensor for side airbag: rear: driver side:
    Serial number: 35128RB4000045C698CV
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 35228RB400004637F1BN
    Crash sensor for front airbag: driver side:
    Serial number: 35547RB40000464582BK
    Crash sensor for front airbag: front passenger side:
    Serial number: 35647RB400004645839K
    1 Fault Found:
    12670208 - No Communication with Instrument Cluster
    U0155 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 226
    Mileage: 175776 km
    Date: 2017.09.09
    Time: 00:07:49
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 036 0070
    Coding: 0000041
    Shop #: WSC 12345 123 12345
    VCID: 78FF82860B12618298-802C
    2 Faults Found:
    00888 - Wiper Switch for Intermittent Operation (E22)
    014 - Defective
    01044 - Control Module Incorrectly Coded
    000 - -
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 931 T HW: 8P0 920 931 T
    Component: KOMBIINSTR. VDO H15 0820
    Revision: D0H15004 Serial number: 2246H004006925
    Coding: 0004128
    Shop #: WSC 01286 386 08256
    VCID: 44872676075AF562C4-8010
    No fault code found.
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H-- 0202
    Revision: H-- Serial number: 0000
    Coding: E9827F060002022102
    Shop #: WSC 56299 001 1048576
    VCID: 35614BB25C805CEA43-8060
    1 Fault Found:
    00470 - Company Comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 187
    Mileage: 175803 km
    Time Indication: 0
    Date: 2017.09.07
    Time: 14:32:55
    Address 22: AWD Labels: 0AY-907-554-V1.clb
    Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
    Component: Haldex 4Motion 3016
    Coding: 0000005
    VCID: 4385256A0254F25AFD-8016
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 9
    Mileage: 0 km
    Time Indication: 1
    Veh. life cycle counter: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Status: 00001010
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 9
    Mileage: 0 km
    Time Indication: 1
    Freeze Frame:
    Ign. Timing: 4.5 °BTDC
    Raw, Form. N/A: 000 000 000
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H15004 Serial number: AUX7Z0H9FN60DZ
    Shop #: WSC 00137 211 56823
    2 Faults Found:
    16346 - Control Module - ROM Error
    014 - Defective
    01176 - Key
    008 - Implausible Signal - Intermittent
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
    Component: Tuer-SG H03 0060
    Coding: 0004276
    VCID: 428B206E1D4EFB52F6-8016
    3 Faults Found:
    00939 - Mirror Adjust Motor; Drivers Side (V149)
    012 - Electrical Fault in Circuit - Intermittent
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    00109 - Left Mirror Turn Signal Lamp (L131)
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 233 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5B68CE853E0312DE-807E
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 L
    Component: KSG H11 0080
    Coding: 1880202002186D098D0D4C8F0167
    VCID: 45813B720C60CC6AD3-8010
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    1 Fault Found:
    00332 - Control Circuit for Tank Flap
    007 - Short to Ground
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
    Coding: 0004276
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
    Component: R Chorus2+ H20 0270
    Revision: 00H20000 Serial number: AUZ1Z2H2534151
    Coding: 0000221
    VCID: 2B556DCA8AC41A1A25-807E
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 226
    Mileage: 0 km
    Time Indication: 0
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    VCID: 41892F621848E04AEF-8014
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000144
    End-------------------------(Elapsed Time: 02:03)--------------------------
  2. #782
    Sep 2009
    abs pump 1K0 614 517 ED
    abs module
    1K0 907 379 BM ESP MK60EC1 H46 0164
    JETTA 2014 USA
    3VW2K7AJ7EM323188
    LHD , 85Kw gasoline engine, FWD
    no start/stap, no eco, no ESP button, no parktronik, no TPMS
    front brake disc diameter -- not know
  3. #783
    Dec 2013
    Poland
    Hi gave you the wrong vin number.
    WAUZZZ8P4AA030646
    And I have a fault with this title
    (Coding rejected. Error 31: Request out of range.)
    What should I do as I have the same error?
    Quote Originally Posted by hid3 View Post
    Hello,
    please try this coding
    1342201209230000C80E04E8901900813800
  4. #784
    Mar 2011
    EU
    11424012092300FA881004EB902100413C00
    Doen't work I tried lot of coding but nothing work, this car make me crazy ...
  5. #785
    Nov 2009
    WAUZZZ8P5BA156886
    1K0907379BD ABS/ESP
    AUDİ A3 2011
    HELP PLEASE
  6. #786
    Aug 2011
    Need one long coding for this car:
    Control Module Part Number: 1K0 907 379BD
    Component and/or Version: ESP MK60EC1
    SKODA OCTAVIA
    Engine code BXE
    Year 2009
    VIN: TMBBS61Z8A2017735
    Manual Gearbox
    Has got ESP button
    No start and stop
    Thank you very much
  7. #787
    Brolk's Avatar
    May 2016
    ARGENTINA Bs.As
    HI please help coding A3
    Thursday,14,September,2017,19:39:33:04550
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 15.7.0.2
    Data version: 20150820
    www.Ross-Tech.com
    VIN: WAUHA28P99A114872 License Plate: IDE745
    Mileage: 101080km-62808mi Repair Order:
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUHA28P99A114872 Mileage: 101080km-62808miles
    02-Auto Trans -- Status: Malfunction 0010
    04-Steering Angle -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (BSE) Labels: 06A-906-033-BGU.lbl
    Part No SW: 06A 906 033 JM HW: 06A 906 033 JL
    Component: BSE S71 1.6 2V 3462
    Revision: --H01--- Serial number: AUX7Z0I1FN609K
    Coding: 0044077
    VCID: 73000EC3D2BA788AC8BCA2-8026
    1 Fault Found:
    18036 - Powertrain Data Bus
    P1628 - 009 - Missing Message from Steering Angle Sensor
    Freeze Frame:
    Hex Value: 0x0000
    Speed: 0.0 km/h
    (no units): 1.0
    Bin. Bits: 00000001
    Hex Value: 0x0000
    Speed: 0.0 km/h
    (no units): 1.0
    Bin. Bits: 00000001
    Readiness: 0110 1101
    Address 02: Auto Trans Labels: 0AM-927-769.clb
    Part No SW: 0AM 300 048 Q HW: 0AM 927 769 D
    Component: GSG DSG AG7 431 9033
    Revision: 00043014 Serial number: CU501608046318
    Coding: 0000020
    Shop #: WSC 04940 001 00001
    VCID: 3E96EFF7A978E5E2F752FB-806A
    1 Fault Found:
    006243 - Powertrain Data Bus
    P1863 - 000 - Missing Message from Steering Angle Sensor
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 8
    Reset counter: 10
    Mileage: 101084 km
    Time Indication: 0
    Date: 2017.09.13
    Time: 03:34:23
    Revision: 00H35001
    Shop #: WSC 34696 002 1048576
    VCID: 750430DBDCCEA6BAE6A85C-8020
    4 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 101084 km
    Time Indication: 0
    Date: 2017.09.13
    Time: 03:58:33
    Freeze Frame:
    Count: 16391
    Count: 12
    Count: 12288
    Count: 320
    Count: 47616
    Count: 0
    Count: 0
    Count: 0
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 101084 km
    Time Indication: 0
    Date: 2017.09.13
    Time: 03:58:33
    Freeze Frame:
    Count: 16391
    Count: 12
    Count: 12288
    Count: 295
    Count: 47616
    Count: 0
    Count: 0
    Count: 0
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 101084 km
    Time Indication: 0
    Date: 2017.09.13
    Time: 03:58:33
    Freeze Frame:
    Count: 16391
    Count: 12
    Count: 12288
    Count: 195
    Count: 47616
    Count: 0
    Count: 0
    Count: 0
    00150 - Plausibility Brake Booster System
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 101084 km
    Time Indication: 0
    Date: 2017.09.13
    Time: 03:58:28
    Freeze Frame:
    Count: 3
    Count: 12
    Count: 12800
    Count: 398
    Count: 50432
    Count: 0
    Count: 0
    Count: 0
    Revision: 000796 Serial number: 8P0820043BG
    VCID: 720E0BC7ADA07182C34ABF-8026
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 92
    Reset counter: 98
    Mileage: 101050 km
    Time Indication: 0
    Date: 2017.09.06
    Time: 08:57:19
    Freeze Frame:
    Voltage: 14.20 V
    Temperature: 18.5°C
    (no units): 231.0
    (no units): 157.0
    Temperature: 15.0°C
    Revision: 00H54000 Serial number: 00000009384221
    Coding: 01AC2F8190141380EF00001C0000000000094E056401040100 A800000000
    VCID: 487A892FFBBCAB524DEE4D-801C
    Coding: 00056595
    Shop #: WSC 06314
    1 Fault Found:
    01518 - Bulb for Back-Up Lights; Left (M16)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 101084 km
    Time Indication: 0
    Date: 2017.09.13
    Time: 03:58:00
    Freeze Frame:
    ON
    Voltage: 14.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    Revision: -------- Serial number: 003CA004Y7ZJ
    Coding: 303142383038303031314A55304C38503053
    VCID: 497C8C2BE0B69A5A52E070-801C
    Crash sensor for side airbag; driver side:
    Serial number: 3572DRB4000088E4C8DA
    Crash sensor for side airbag; front passenger side:
    Serial number: 3582DRB4000088E4C0D3
    Crash sensor for side airbag; rear; driver side:
    Serial number: 35128RB400004ACBBE71
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 35228RB400004ACA9F6%
    Crash sensor for front airbag; driver side:
    Serial number: 35547RB400004B45A67R
    Crash sensor for front airbag; front passenger side:
    Serial number: 35647RB400004B45CA1S
    Coding: 0010002
    VCID: 781A39EFCBDC1BD2FD8E7D-802C
    Component: KOMBIINSTR. VDO H19 0860
    Revision: D0H19007 Serial number: 2241I007039373
    Coding: 0002128
    Shop #: WSC 05011 985 83503
    VCID: 44629D1FC7948F32A196B9-8010
    Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533__Gateway H16 0210
    Revision: H16 Serial number: 3400K0920401DB
    Coding: ED807F06100202002102
    VCID: 3798FAD38642D4AA341436-8062
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 101084 km
    Time Indication: 0
    Date: 2017.09.13
    Time: 03:34:23
    Revision: D0H19007 Serial number: AUX7Z0I1FN609K
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Coding: 0000180
    VCID: 43609E03C29A880A989CB2-8016
    Part No: 1K0 909 144 E
    Component: EPS_ZFLS Kl. 232 2501
    Revision: 00H15000
    VCID: 2CB2D5BF4F0467724986B1-8078
    Part No: 8P0 959 433 K
    Coding: 1880202002186D0985054C8FC677
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
    Component: AB2 SUBWOOFERBOXH07 0180
    Revision: 00006 Serial number: 92158837419623
    VCID: 3686F7D781482DA22F2203-8062
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000180
    Part No SW: 8P0 035 186 Q HW: 8P0 035 186 Q
    Component: R Concert2+ H03 0270
    Revision: 00H03000 Serial number: AUZ1Z3I9807060
    Coding: 0110212
    VCID: 406A910FD38C931285BE95-8014
    Coding: 0000144
    VCID: 416C940BD8869A1A8AB098-8014
    Coding: 0000144
    VCID: 426E9B07DD80810293AA8F-8016
    End-------------------------(Elapsed Time: 02:05)--------------------------
    Brolk..
    Press "THANKS" button.
  8. #788
    lush29's Avatar
    Oct 2015
    hi all,
    need help after someone lost codding.
    car is seat Leon 2009,2.0tdi engine bmn engine code,abs part no 1k0907379an,mk60ec1 h450107.tmps,
    car is manual,no start stop system and vcds log attaced. thanks
  9. #789
    Aug 2009
    Default SEAT IBIZA NEED LONG CODING ESP 8.2i
    SEAT IBIZA 1.2TSI
    YEAR 2011
    6R0907379BC
    ESP 8.2i front H05 0002
    WSC 04941
    VIN VSSZZZ6JZCR109516
    CODE MOTORE CBZB
    THANKS
  10. #790
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by lush29 View Post
    hi all,
    No one lease?
  11. #791
    Jul 2016
    Vilnius
    Hello,
    please try this coding:
    110228DB216D00BB882A14E384D700401700
    Also, for Polo-based modules there is a separate thread...
    Quote Originally Posted by gogoli View Post
    SEAT IBIZA 1.2TSI
    YEAR 2011
    6R0907379BC
    WSC 04941
    CODE MOTORE CBZB
    THANKS
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
  12. #792
    Jul 2016
    Vilnius
    Quote Originally Posted by Brolk View Post
    Hi!
    Autoscan is OK, but could you please suppoly some additional information listed here: http://www.digital-kaos.co.uk/forums...=1#post2835479
    Thank you
    * MK100
  13. #793
    Jul 2016
    Vilnius
    Quote Originally Posted by tibor 12345 View Post
    SKODA OCTAVIA
    Engine code BXE
    Year 2009
    Manual Gearbox
    Has got ESP button
    No start and stop
    Thank you very much
    Hello,
    assuming it is LHD, try this:
    113B201C0A230001881204E7501E0041300800
    * MK100
  14. #794
    Jul 2016
    Vilnius
    Quote Originally Posted by alizczewy View Post
    WAUZZZ8P4AA030646
    Hello,
    for the given VIN it should be like this:
    13422012092500FAC81104E8901F00813800
    * MK100
  15. #795
    Jul 2016
    Vilnius
    If anyone else feels forgotten, please re-post your request, I'll try to assist.
    * MK100
