superman good man
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
His provided coding will not work anyway
Guys, I have a question - does anyone know Security Access code for 1K0 907 379 BJ (or possibly others too) module in order to disable Brake Disk Wiping function in Adaptations 55 channel?
Thank you
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
Friday,16,November,2018,20:19:55:38201
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 18.9.0.2 HEX-NET CB: 0.4441.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: VSSZZZ6JZ9R015501 License Plate:
Mileage: 158430km-98443mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 05 08 09 15 17 19 25 44 4B 56 77
VIN: VSSZZZ6JZ9R015501 Mileage: 158430km-98443miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 HW: 6R0 907 379
Component: ABS8.2 front H03 0004
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 7BB60010FE70599280-802E
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 10
Reset counter: 184
Mileage: 158435 km
Time Indication: 0
Date: 2013.03.22
Time: 03:52:45
Freeze Frame:
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3013
Hex Value: 0x1495
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 05: Acc/Start Auth.
Cannot be reached
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000010222-
Shop #: WSC 00000 000 00000
VCID: 63865870A2C08152A8-8036
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H06 0011
Revision: BF006001 Serial number: 9425A136080205
Coding: 7C882FB88861010000300000760B1CC80040400F608C000020 00
Shop #: WSC 12345 123 54321
VCID: 7AB80514F54A609A9B-802E
Subsystem 1 - Part No SW: 6R0 959 802 HW: 6R0 959 802 Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 001 0221
Serial number: --------------------
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 B HW: 6R0 959 801 B Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 001 0225
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3110
Coding: 000000
Subsystem 4 - Part No SW: 6R0 959 812 HW: 6R0 959 812
Component: J389__TSG_HR 001 0228
Coding: 000000
1 Fault Found:
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 184
Mileage: 158435 km
Time Indication: 0
Date: 2013.03.21
Time: 23:36:11
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 HW: 6R0 959 655
Component: VW10AirbagA05 H07 0013
Revision: -------- Serial number: 003000000000
Coding: 003035
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 7F4EF400E66845B2AC-802A
Crash sensor for side airbag: driver side:
Serial number: 3492ERB401V5G346UK2K
Crash sensor for side airbag: front passenger side:
Serial number: 3502ERB401V5G346SKMU
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6J0 920 900 K HW: 6J0 920 900 K
Component: KOMBI 016 0016
Serial number: 00000000000000
Coding: 410A00
Shop #: WSC 06403 785 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 2F2EE440768875327C-807A
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0011
Coding: 022300
VCID: 70AC273CA3362ACA25-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO 016 0016
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 11241
Shop #: WSC 06403
VCID: 6D923E482004C7220E-8038
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 312AE238A8BC63C26A-8064
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H55 0033
Revision: 0H001001 Serial number: SEZ1Z2H5659244
Coding: 0403040001
Shop #: WSC 04941 123 12345
VCID: 230618702240C152E8-8076
3 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 158435 km
Time Indication: 0
Date: 2013.03.21
Time: 23:01:09
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 158435 km
Time Indication: 0
Date: 2013.03.21
Time: 23:01:09
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 158435 km
Time Indication: 0
Date: 2013.03.22
Time: 02:13:31
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 D HW: 5P0 862 335 D
Component: FSE_2P7x H31 0120
Revision: 00000001 Serial number: 00000005001520
Coding: 0000720
VCID: 3424EB2C57AE56EA01-8060
End----(Elapsed Time: 01:45, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Hi all friends,
Need long coding for ABS Golf 6 2010 MK60ec1
here is VIN : WVWZZZ1KZAM686334
Unit is 1K0907379AJ
Manual gearbox , right hand drive 1.6 diesel
thanks in advance
BR
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
Reality of life :
3:Everyone lies
I have an US Tiguan, wich sould be migrated to EU.
I have changes the modul for parking break and the bluetooth modul.
The adaption for the parking break i have done with success.
The ABS and the airbag a bad until now.
Maybe i can d the full scan in english if needed.
Adresse 03: Bremsenelektronik Labeldatei: 5N0-614-109-C6.clb
Teilenummer SW: 5N0 614 109 AP HW: 5N0 614 109 AP
Bauteil: J104 C6 450M VD14 0005
Revision: --H07--- Seriennummer: 00000005077264
Codierung: 0005158
Betriebsnr.: WSC 01324 020 00200
VCID: 79861461BBCE2F135D-802C
3 Fehlercodes gefunden:
01044 - Steuergerät falsch codiert
000 - -
01317 - Steuergerät im Schalttafeleinsatz (J285)
000 - -
00778 - Geber für Lenkwinkel (G85)
005 - keine oder falsche Grundeinstellung/Adaption
Fahrzeug-Ident.-Nr.: WVGAV7AX8CW004398
Fahrzeugtyp: AX-VW36 (7N0)
LHD
2.0 TFSI GASoline
FWD / 2WD
No STart/Stop
TPMS---- here i might have a problem
4C-Reifendruck II -- Status: nicht erreichbar 1100.
In the
VCDS Scan i had an fault that the TPMS II would not bei reached.
I do not think to have sensors in the tire valves.
Ich denke nicht, das er eine Reifendrucküberwachung hat.Vielleicht über den Abrollumfangmaybe it it monitored indirect over the ABS.
ESP switch in center console
No hill hold
And i think that a thanks ist not enough to you if this will work. (:-))
It looks like you changed the Instruments coding to Europe.
If you change it back to USA, do the fault codes go away?
In fact, Tiguan is a bit problematic vehicle. You can set the region to Canada in the Instruments and try to be happy with that.
But if you are not happy, please be ready for some more pain recoding it
* MK100;
Yes i changed the coding of instrument cluster to show km , Celsius usw. The clock i did not get working in 24h. It shows AM and PM.
I will try to change it back during the week and report whats happened.
Is there a chance to get a 100% working EU Version?
A complete EU instrument cluster i have...but i am not familiar with the immobilizer.
Regards
If you want fairly easy fight, as mentioned, change to Canada and if the car has got full MFD, then via the menu change units to *C and the clock.
Also, you could do a fresh AutoScan using English version of VCDS and share it - maybe someone could help you
* MK100;
Hicom300 (20th November, 2018)
Can you help please with coding Touran 2011 2.0TDi , manual 6speed , RHD , ABS MK60EC1 1K0907379BE,
Vin ; WVGZZZ1TZBW102002
Thanks Greg
hello
can you help me golf 7 esp long coding (electronic brakes)
vin:WVWZZZAUZEW111525
PART N° VW/AUDI : 5Q0907379AB
SN:60414000000311
01 FA 8A A1 34 21 09 6D 03 7C 06 02 41 C8 29 80 51 2C 90 C0 60 82 94 F5 F8 62 50 F8 C1 09
8278,U1014 00(137) -Control Module Incorrectly Coded
tanks
Need Long Code help!
ECU: 1K0907379CB
VIN: 3VWLV6167GM003180
DASH NUMBER:5C6920885A
VW JETTA 2016 2.0 TSI
HELP PLEASE...
Regards
Hello mate,
Sorry for the late reply as I have been busy at work.
That code you sent me didn’t work
