Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 80
  1. #16
    eprst's Avatar
    Jul 2011
    Russia
    I used it to connect
    power to regular connector
  2. #17
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    V850 chip in my navigation is locked.
  3. #18
    Sep 2016
    It seems that the MMI3GEmergencyApp should be able to flash the V850.
    If you look at it you can find "ForceIocUpdateFromEmergency".
    Now i wonder if i put ForceIocUpdateFromEmergency = "true" in the metainfo2.txt and force the unit in Emergency mode will it be able to fix my issue.
    Because i have somehow different problem ... wrong firmware, 3GP firmware in 3G High unit.
    That's why i'm not sure that even if that parameter is correct and it's places is in the metainfo2.txt that the MMI3GEmergencyApp will be able to do it because of the wrong firmware
    Cheers.
  4. #19
    eprst's Avatar
    Jul 2011
    Russia
    V850 chip is locked. this does not prevent him to write down
  5. #20
    Sep 2016
    It shouldn't be hardware locked as the update process is able to write to it, it's just needs to be in bootloader mode in order to write.
    I know for sure that MMI3GEmergencyApp can put it in that mode. I also know that it's possible to recover it from that mode just don't know the exact steps .... yet.
    If we sniff one unit during update procedure maybe we can see what is happening behind the curtains.
    Keldo and some others can do that w/o even touching the chip so it's possible. The updater can do it to.
    Harman/Becker for sure know that there is a chance that during the update the power might goes down and the unit should be able to recover from that.....
    After all this is not some fancy satellite ... it's just a multimedia unit
    If you find something i will write
  6. #21
    eprst's Avatar
    Jul 2011
    Russia
    It is easy, just write chip
  7. #22
    Sep 2016
    Getting there Using the parameter from above the MMI went in bolo mode after the emergency flash finished but i had an error in the metainfo somewhere ... will try again tomorrow.
    If i got you right, i will give the V850 power on pin 9 and 11 and should not power the MMI right?
  8. #23
    Sep 2016
    The main CPU cannot see the V850
    Will have to try with direct connection
    KR.
  9. #24
    I can restore MMI 3G, 3GP and RNS850 from any state. I can make from 3G - 3GP, have V850 working dump, write 2 flash by JTAG and other many year i lost for it.
  10. The Following User Says Thank You to Crash-100 For This Useful Post:
    soxten (10th July, 2017)
  11. #25
    Sep 2016
    We all know about you I admire your work and even asked you once about converting 3G high to 3G plus but you never answered me.
    If you can help here with some guidelines or something then you are welcome. If you just want to make an advertisement... then we got your point. The fact is that with trial and error I was able to get the IPL back and then flashed the unit. If I succeed with V850 then good if I don't ... well that's life.
    You can post your prices so that we know.
    Cheers.
    Sent from my iPad using Tapatalk
  12. #26
    Where are you from ?
    Can you sen divece for me ?
  13. #27
    Sep 2016
    You have PM
  14. #28
    Sep 2016
    Quote Originally Posted by Crash-100 View Post
    I'm from Bulgaria.
    I do prefer to fix it locally just because it's interesting to me. I've tried many ways in order to fix it w/o removing the chip or trying to reprogram it on board. Even disassembled part of the code, that's how I found the way to try and force the IOC update
    It seems that we will need to try wit direct connection to the chip
    Cheers.
  15. #29
    eprst's Avatar
    Jul 2011
    Russia
    I gave you the information as a record processor
  16. The Following 2 Users Say Thank You to eprst For This Useful Post:
    jackie86 (7th January, 2017), Youneselm (19th October, 2016)
  17. #30
    Jan 2017
    Hi congobg,
    Did you have any luck in this issue?
