Ok, I already place the order for Tiao but I hope that segger can read too. I try on portions, I read first the IPL, next fpga and so on. It reads but it reads incorrectly. On the first page eprst use segger and he manage to read.
I was try also a year ago with segger but never done, when you get your Tiao all will be fine!
tehnosoftex (24th June, 2017)
Today i had some strange experience with one MMI 3GP unit.
I was able to write both flash chips but, when Y17 (flash chip 2) i was able to write only on portions of 256k each.
I used 5Mgh TCK, do not check write status (really slow write w/o this) and use unlock bypass mode.
Used TIAO USB JTAG with TopJTAG Flash.
This way i flashed the IPL in one pass, FPGA on three passes and emg ifs on 19 passes
Anyone have idea what is not right. Flash chip 1 is ok, 2 MB pieces and the 5-6 min timeout is ok.
Regards.
Today get my tiao usb but cannot see any device in jtag chain. With segger I identify correctly the renesas sh4 and can read. There is some settings that I must do to use tiao?
Ofcourse without boot settings or files its not possible to communicate...
I use topjtag flash programmer with the same settings like for segger but I chose tiao adapter from top jtag. I try all jumper settings on tiao, same result, no device find on jtag chain. On segger top jtag identifies at once the renesas mcu on jtag chain. I use r7785b bsdl file
I managed at last to communicate, Ive chose tiao interface type a instead of type b and it works
What about a24? To read both flashes need a0-a24 connected but according the connection from first page I connect only a0-a23, and can read only a half of firmware.
Sorry. Wrong post..
Hi mates, any news?
anyone done similar things for bmw cic and have flash and v850 files? I have done some extracting from spdatens and need someone to confirm that Im doing something right .
did you succeed? I did something similar
