Results 1 to 5 of 5
    Top Poster skydive80's Avatar
    Out The Box
    Default Original DM800HDd
    Hi guys,
    looking for a little help please if pos, I digged out my original DM800HD and decided to flash it with a cloned image thinking it will be ok, I now got the dreaded NO CA ERROR, I have had this in the past and used dreamup to fix the error however this time every image I put on this box it tells me wrong image or old image, I have tried changing the boot loader and putting on a original dreambox image and still the same problem, I have read I need to put the original Gemini image on the box (factory one) but I can't find a copy anywhere.
    also tried the dreambox tool but no luck.
    any suggestions guys would be much greatfull.
    many thanks,
    digicon's Avatar
    There are plenty of gemeini Images in the download section perhaps work your way backwards from the end posts to find a suitable one, Dreamup 1336 has never failed me yet on the 'No CA Error' also should be in the downloads
  3. The Following User Says Thank You to digicon For This Useful Post:
    skydive80 (26th April, 2016)
    Out The Box
    Thanks bud, found an image from dreambox downloads and used dreamup you suggested and now working..... a thanks again
  5. The Following User Says Thank You to skydive80 For This Useful Post:
    digicon (27th April, 2016)
  6. #4
    digicon's Avatar
    No Problem just glad you managed to get it sorted
    Well done
    toysoft's Avatar
    Nov 2008
    Use JapharFlasher,
    TS
    MEGA :
    PHP Code:
    https://mega.nz/#!7c4RDSBR!tHuDF-84p1L_VYcCLK2FMiZauIQTBL9uQievaNpLq4U
