Results 1 to 4 of 4
    May 2010
    Default probook 6560b battery charging problem
    hello,
    i have a problem with my noebook probook 6560b,battery appears to charg but it does not,it stays only 40%,i tested the battery on other notebook it works.
    Anywhere that can help me to find a solution
    thanks in advance
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Look up HP hard reset to resolve hardware or software issues. Alternatively testing and calibrating the battery using HP system diagnostics.
  3. The Following User Says Thank You to DOUGALMCD For This Useful Post:
    flamurf (27th April, 2016)
    May 2010
    a flash a new bios,i mean harder as this method are nothing,but this problem still stand again
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    I saw this on hp site may or may not help you.
    I was able to fix it by doing these steps.
    Device Manage -> Batteries - Uninstalled Microsoft ACPI-Complient Control Method Battery -> Removed my battery from my laptop - waited about a minute -> put it back in and scanned fo hardware changes.
    Computer is now charging!
