looking on the forum here and find how to read the eeprom from this ecu.after that post your dump and someone guy make immo off for you.
regard's
i NEED IMMO OFF SOLUTION FOR FIAT pANDA
IAW 5NF.S8 51788362
EPROM 95160fiat_5nf.zipFLASH.zip
fLASH
tHANKS
regard's
SPIROS2105 (27th April, 2016)
i FIX IT
I READ IT WITH UPA AND THE FILES ARE IN FIRST POST
THANKS ANTONIS
Non ce nessuno che riesce a fare immo off?
I need immo off too.
Did this worked?
post your dump from eeprom.....95160.
Here is it.......i got key error in ecu and in siemens body computer.
abdonete (22nd January, 2019), alfa8x (12th November, 2021), hellmet (7th July, 2022), Master8 (16th July, 2023), monter5555 (17th August, 2019), nokwueze (24th September, 2022), PaoloDigital (16th July, 2022)
Ok thanks.I will post result.
Guys........this is a 100% fix.Thank you antwnhszr for make the dump work.
On iaw5nf.s8 ecu you need to cut wire on B plug pin 16 and connect it to B plug pin 29.................and car starts.(with eeprom immo off).Hell of a work since eeprom is on back site of the ecu.Thank you for that Marreli.
Hello pass please for file antwnhszr
ĦĦĦĦĦĦIf my information served to help you, please click on THANKS + REPUTATION!!!!!
Pass please thanks
post eeprom data ....
Helo , have to make tfis ecu , have please password for file quote, or make me ather file . The mod byte are common calssic as adress line 90 A0 ?
And explain exactly how is the issue of pins, momentary or definitive?
I indicate you as connect tis ecu with adaptor UPA and schematic
In have same problem with a Fiat panda 2005 with IAW 5NF S.8
I prepared the file as t1, t2 and I cut pin 16 by connecting it to pin 29 of socket b but nothing, the car doesn't start
can you prepare the file for me? thanks friend
