I was wondering about Orange 5 clone and just a random eeprom programmer from Amazon, brought the latter. I'm genuinely impress for 100 dollar price. It's called "SOFI SP8"
If I helped you, feel free to drop me that sweet sweet +1 thank you.
I read Nissan Qashqai J10 BCM 284b2 jd 12a by Orange5. There was only one option under Immo Mazda2 09- to read this MCU9s12xdt384(1L15Y). Read fine, Tango can show keys and login but I can't write new key. When I add .bin file information appear "Add key not tested" Wnen I write key or transponder pcf7936 info display "invalid crypto key" and it change chip page 3 from 06 to 0E making it crypto mode. Car has proximity twist on ignition/ key I tried original dealer key also blank pcf7936 and preceded for xtrail qashqai.
I tested also two random eeprom from DK file 4KB the same situation but one file 2kb write the key with no problem.
My question is did someone face this problem? where is the problem? can I use 2kb eeprom file with key from different car and write to my module with original flash?
Did you try with another key maker tool? Tango is not the only one.
no I did not. I have only tango key maker I Will upload files if someone can try to write on emulated chip like LKP03 can be errased so no lost. Please help
QashqaiBCM_VDO.rar
VVDI2 EEPROM recognized and recorded it.
redliner (4th June, 2021)
Yes I know that, Tango same recognized but did not write new key only change chip page 3 to 0E crypto and did not give new file to save and write back to MCU. If you can confirm that pcf7936 written succesfully and give you file to save ?
I can see VVDI2 show key no.1 ID can you get all key information so I can retrieve key no.1 and write data on emulated chip? or please write new key on emulated chip so you can give me new file and transponder contents of 2nd key I will be able to intput data to my chip with your help.
The problem is that I can't program key by OBD because something wrong with car installation (car ~~~ed from auction) and steering lock can't release ( new steering lock doesn't work as well) I was hopping probram the key directly to eeprom using Orange5 and Tango but this not work either.
I'm looking for color codes of Orange5...
Anyone have it ?
Polak, wegier dwa bratanki i do szabli i do szklanki
I personally don't use colour codes wirh orange5 because wires are loose and the colours can be different or misleading depending on schematic but I make a little aid connection from my r270 programmer comparing to orange5 as some connection has different name.
Use the names instead of colours and you don't make a mistake.
#1 +5v (VDDR, VCC) BLUE
#7 RST (RESET) BLACK
#19 BKGD/RXD/BDM GREY
#26 GND (VSSR) BROWN
Those four wires I was using to read MCU recently. Don't know how other people but this work for me.
szkeptmen (6th June, 2021)
I'm like to know this wires / functions
Photo attached / from author...
Derbi Senda bike / dash
inside HC908LJ12
THX + REP
How about now?
redliner (7th June, 2021)
Sorry my orange version doesn't have this mcu and schematic to see it. I made myself orange5 wire colour code bassed on all schematic pictures I have but did not trace blue or grey colour.
BLACK - GND
YELLOW - RXD
ORANGE - TXD
GREEN - RST
- OSC
WHITE - AS/PDX
PURPLE - V10V/VPPR
RED - VCC
- VLim
-GND
Has anyone had success reading or writing to a MC68HC705B16 CFN ? Mask code is 0D28J
I have no problems at all reading MC68HC05B6, B8 or B16, all with different mask codes, but cannot read or write to the 705B16,
it always says "MCU not answer".
I checked the connections, even re-soldered them, and tried several chips (all new, original), but cannot get it to work.
Any suggestions? I may also consider other programmers, if you got anything in mind that reliably works with the 68HC05/68HC705 MCUs
I think original xprog is safer for those
Tools: mb sd connect, avdi(mb), vvdi prog, orange clone, orig upa
got this version 1.36 and want to read R7F7010193 SRS Kia
But wend I choose the MCU the software give me this error !
Is safe to do this width clone ?
Somebody have done it ?
is on MT or SE mode ? or must use adapter ?
thank"s in advance
My work is my life ART TECH GARAGE
