Page 7 of 16 FirstFirst ... 23456789101112 ... LastLast
Results 91 to 105 of 237
  1. #91
    lion0304's Avatar
    Oct 2014
    Default NATS BDM selfmade
    It made this adapter to working with Nissan NATS, tested NATS 4 easy work, not have NATS 5 for test yet
  2. The Following 3 Users Say Thank You to lion0304 For This Useful Post:
    issam216 (28th November, 2017), lidons (4th November, 2017), OleksandrElektrik (14th November, 2018)
  3. #92
    Oct 2017
    i tried many time to read RH66 but not able to read it using clone orange5.it is simple 66 serial eeprom. anyone have luck with this?
  4. #93
    Apr 2014
    Got this message when I tried to read BCM2 uPD 70F3381. Checked voltage at connection and got way below the required 3.26V. Any suggestions?
    Sent from my SM-G930F using Tapatalk
  5. #94
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I have orange5 original and did not read elv from.a6 4f
    Here to HELP!
  6. #95
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Quote Originally Posted by lion0304 View Post
    I want to make this adaptor. Can you tell pinout like in picture. What to what connect?
  7. #96
    Trstenik - Thun
    Connection diagram is inside orange5
  8. The Following User Says Thank You to mikroel For This Useful Post:
    drugowaz (25th November, 2017)
  9. #97
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by drugowaz View Post
    Here it is. More clear than manual.
    All in one page for easiest working on bench
  10. The Following 3 Users Say Thank You to lion0304 For This Useful Post:
    drugowaz (26th November, 2017), mexanico1971 (29th May, 2023), tzveti (7th February, 2019)
  11. #98
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Good. Here i see 500ohm resistor. But found officual orange manual diagram. There is 2kohm resistor
  12. #99
    lion0304's Avatar
    Oct 2014
    560 Ohm or 2k, not important here. Only use for current LED brighning
  13. The Following User Says Thank You to lion0304 For This Useful Post:
  14. #100
    drugowaz's Avatar
    Mar 2015
    Lithuania
  15. #101
    lion0304's Avatar
    Oct 2014
    Yes the LED like that. Resistor using for limited reverse current that can detroy the led.
    My LED use 12V so 560 Ohm give me good luminosity. Usual Led use 12V need 560 ohm resistor.
  16. The Following User Says Thank You to lion0304 For This Useful Post:
  17. #102
    drugowaz's Avatar
    Mar 2015
    Lithuania
    hi,can anyone full words?
    gnd ground
    RXD ...?
    TXD..?
    RST reset
    OSC...?
    PDX...?
    VCC power feed
    AS..?
    VL...?
    which one is bkgd pin by orange shortquts?
    want to read s9s08dz60
  18. #103
    Nov 2012
    I tried renesas m32c M30879FK from rcd210 Vw , and it is just not working.
    It reads flash partialy then error .
    BKGND is RXD. Push info on the programmer and you have all you need.
  19. #104
    Feb 2017
    UK
    Hi everyone This is my second attempt to reset pcf7941 using Orange5 I will share what I discovered, maybe someone has gone further and can share knowledge.
    At the beginning I will say I did not have the Chrysler used key to test with pcf7941. With the Orange5 info it's written that can unlock any pcf7941 so I used some Vaux/Opel keys , desolder chip and try it . I put the Chrysler data and it didn't unlock at all. Programmer start to do the job and get "error 9" at the end, chip still locked and frequency working as before.
    another test was with completely blank new chips and was written correctly but it can be only used for Chrysler fobik keys that I don't have possibility to test with the car.
    My thoughts are that maybe it does not unlock these chips because they really are not pcf7941 as it's different mark on them and they may only recognized by the readers as pcf 7941.
    I go furher and I got the data for pcf7941 Insignia astra J 2 button key and try use this instead of Chrysler.bin file. I thought that it should work but the error come out se picture.
    As we can see the Orange5 software is secured and the other file then Chrysler.bin can't be used.
    My question is did someone brake this or know what to do to use different file?. Unlocking Orange function is useles for now as it's not unlocking at all only writte Chrysler data on empty chip.
  20. #105
    abu deab's Avatar
    Hi all my friends please help
    I am in the process of acquiring an O5 product but I do not want to fall victim to cheating and deception as the previous time
    How do I distinguish the original product from the cloned?
    Please help and have some pictures
    you're welcome
    BY ABU DIAB
