Not that one plus i do hope you read the rules regarding line talk .
information given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix It
Come maca only give the member a break they only joined in 2010 & not had chance to check the rules out
Bought a VM **what's it **.....for the openbox....I see lots of question's soon
As for the boxes joe516 points out that should be fun
Joe no disrespect intended great link
Again NO offence to the OP ........If you buy a VM ** what's it** for the open box
you may struggle with the boxes Joe points out they are defo not plug & play mate
need some help i had VM service before and skybox V8 was working perfect with home plugs now i changed to sly and slybox V8 is working perfect but my friend had VM and VO+ box working perfect now he changed to sly and home plugs are not working and direct ethernet from router to vo+box not working at all any help would be appriciated
if he had a cable box before and now lost the live feed,sly bb would be of no use as cable boxes need a cable feed to scan on and any internet provider.
it was with the dish no cable
yes it was with the cable before but now its with sly any solution for that
its was 100% sat box not a cable box sir
VU+ sat box was running perfect with VM broadband but now with sly broadband home plugs not working and neither direct Ethernet cable from router to the box urgent help needed.Thanks in advance
you did a network test on box and no connection? try powering off box and router as its a common fix.
paul93 (3rd May, 2016)
Thanks it worked
