This is separate remote and transponder, you need precoded transporder and manual program remote
Sent from my VOYAGER2_DG310 using Tapatalk
I used original key 6370A159, that was already precoded. I program old and new keys into the car, but couldn't program remote.
I used FVDI tools and X100 Pro tool and both tools didn't add remote to the car. Only old remote still works.
Maybe these tools can't do this procedure ?
Basically I do this years by obd, gscan or avdi, but you.can try connect to immo with scan tool or x100 than push on off hazard button 7 times than push remote button, take a look in Google because I can't answer all your questions
vitimax (25th June, 2016)
Mitsubishi Eclipse 2007 - obd2 pin 1 to ground and 4(?) times on/off hazard button, then push button on remote and ok. Search on google. Meybe work.
Zed Full works 1st time every time I have done this remote.
I did once on skp900, but it took half an hour, and only worked once I disconnected the device, then reconnected and tried again.
Definitely separate remote and chip.
It was the "hold lock and unlock for 3 flashes, then lock or unlock for 1 flash.
All done on KD. The one I did on skp900 came back 2 months later and stopped working, re did it on ZF and hasn't come back since.
And all remotes are deleted when you need to add 1
Sent from my SM-G935F using Tapatalk
Knowing Mitsu, its probably a manual procedure for remote. Proxy should be automatic when you program the key
