Results 1 to 13 of 13
Thread: fvdi killed bsi
    Apr 2016
    Default fvdi killed bsi
    hi does any body know how to restore my bsi from boot mode after attempting to read
    pin code with fvdi
    any help would be great full
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by cpsautos View Post
    pin code with fvdi
    Leave ignition on with good battery charger for about 1 hour. See if that works...
    Sent from my SM-G925F using Tapatalk
  3. The Following 4 Users Say Thank You to lush29 For This Useful Post:
    pouettedu76 (22nd January, 2017), vitzauto (9th June, 2016), wokcz (8th June, 2017), Youneselm (19th July, 2016)
    when reading this bsi with fvdi,always put a battery charger onto vehicle and take out fuses for the lights and wipers, then it will read correctly.
    don't forget to press thanks
  5. The Following 5 Users Say Thank You to radiosolutions For This Useful Post:
    AutoGeek (6th January, 2019), bonecrusher (16th July, 2016), mitch2 (29th January, 2017), Stelaras (20th April, 2017), Stelaras26 (4th May, 2018)
  6. #4
    Jan 2012
    Hi, if You have PSA ACTIA You can chose option off mode... 2 sec radio solutions - good advice.
    regards Peter
    Mar 2015
    Wich BSI is it? VALEO SIEMENS OR JC? and wich model peugeot citroen?
  8. #6
    scotland clydebank
    it will be johnson control read it all the time in this forum avdi will repair it or try with fvdi might wake up.
  9. #7
    H.Wessel's Avatar
    Start the process again but with battery charger on car, one hour later will read pin and exit from boot mode. If not remove bsi and flash it with smok
  10. The Following User Says Thank You to H.Wessel For This Useful Post:
    peugeot (23rd July, 2016)
  11. #8
    Newbie smarelo's Avatar
    Jan 2017
    France
    hello
    you say you can do mode off
    is the mode showroom??
    When you do showroom mode, i don't test but the users say you can't do ignition off in the end of process fvdi read pin...etc
    sorry for my english please
  12. #9
    daynight's Avatar
    Nov 2016
    EU
    for JC BSI need to be disabled economy mode before working with AVDI.
  13. #10
    Jun 2013
    For JC i conect another car with start cables and run. With charge BSI no go to economy mode.
  14. #11
    Cepe Verde
    Finalyy e get the car back to normal state. i had a backup of eeprom file, i desolder and write it with UPA. If was not that i should buy another BSI becouse i flashed the car with wrong flash. when u flash with diferent flash than the original the eeprom get corrupt and u can see it when i get info about BSI in FVDI and u see funny VIN number. In that case u have to have eeprom original. or if some one can try with eeprom from diferent car. Unplug fuses for wiper and beams to save more power. Good lock
  15. #12
    Sep 2012
    if you write new flash different ori you have problem for glasses or other
  16. #13
    Cepe Verde
    yes and u can get eeprom corrupted. u must write with same signature
