Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 54
  1. #31
    otojm's Avatar
    Feb 2012
    Kepler 22b
    please i need 150428CAR00568KW.lib regards
  2. #32
    dantetimoc's Avatar
    Quote Originally Posted by otojm View Post
    atached lib 491KW if needed, i dont have 568kw.
    Autotuner- Kess - Ktag, genuine master tools.
  3. The Following 4 Users Say Thank You to dantetimoc For This Useful Post:
    ferchichi (16th May, 2018), mexanico1971 (2nd July, 2018), otojm (13th January, 2017), t-ortman (1st October, 2018)
  4. #33
    Aug 2008
    here is your lib file merry christmas
  5. The Following 12 Users Say Thank You to tango For This Useful Post:
    alfons37 (1st January, 2017), BlacksunLE (7th April, 2017), brodaty (7th January, 2017), electronistul21 (11th October, 2017), hbalazs (24th December, 2016), ilen (25th January, 2017), latino (26th April, 2019), MASANY (7th January, 2017), Moldovan1 (11th April, 2017), otoozkanuysal (30th May, 2020), szifu2 (6th January, 2017), tehnosoftex (29th December, 2016)
  6. #34
    Jul 2016
    you must rework carprog and A1 adapter
  7. The Following User Says Thank You to jokerdiag For This Useful Post:
    cubica1 (24th February, 2017)
  8. #35
    Hungary
    How can i identify my carprog's fw ? The "carprog online" what i bought is received yesterday , but i get a cd with an exe and a lib file . There are too much n/a on the program, and all online feature are inactive ..
    The lib file name is : 081105CAR001773I.lib and of course the seller doesn't respond
  9. #36
    Aug 2008
    that lib file is for v4.01
    do you have this serial in bottom left corner when you connect carprog to pc?
  10. #37
    Hungary
    Quote Originally Posted by tango View Post
    Yes, unfortunately the serial nr is the same.. I paid 103 use for it ..
  11. #38
    Jul 2016
    Hi, I bought carprog 8.21 online clone because I need swap my cluster with maxi dot one with VDO NEC 24c64. After two days laboring I figured that this tool is not usable for me. Online functions are FAKE! Isnt possible to use this function because original carprog is comunacating with codecard server (On this server are stored algo for seed keys, I think) but this china clone have only server emulator so all request to compute seed key are rejected. I have check canbus communication and carprog send to cluster request for programming mode then cluster send seed and carprog clone reject communication!! So this clone is unusable for features which need online server. THIS TOOL IS USED ONLY FOR VDO NEC WITH 24C32 EEPROM. Immo block in this eeprom isnt encrypted so carprog can read immo block without reading key from nec chip. Server emulator in clone is good only for enabling ONLINE feature but real functionality is missing.
  12. #39
    Dec 2016
    please i need 201213CAR000ME61.lib regards
  13. #40
    Aug 2008
    Quote Originally Posted by pps View Post
    this is the lib for 4.74 serial its on here and all over the net
    get the 4.74 lib file and rename it to this
  14. #41
    Apr 2017
    delete post
  15. #42
    Jul 2017
    Pls i need to activate this version Carprog v821
    19E56-D0804-F5B3A-125CC
  16. #43
    Sep 2010
    Brasil
    Default file lib
    Please, I need Lib file 150428CAR00542UA
  17. #44
    pike's Avatar
    Sep 2013
    Post Lib file 150428CAR00542UA
    Quote Originally Posted by Sucuri View Post
    Your Lib file.
  18. #45
    In EEP
