147 read body 100% ok
And again alfa romeo 147 2004year 912dg128 all ok. little advice if you can't connect to body try to cycle ignition on off then read.
If you compare smok fiat body to other fiat tools, smok is the winner, io terminal have option to read fiat body but it cost 2x smok price and coverage is better in smok.
for fiat zedfull can be a option good but avdi it s the best
vlaki electric (23rd May, 2016)
super jumbe (10th December, 2017)
Nothing for Fiat 500.
Smok work with old body !! not read the Fiat 500, Alfa Romeo Giulietta Mito
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
- IOTerminal not read body computer (NEC ecu 70F3633) by OBD.
This would be a great challenge for Samic's next project.
I prefer this instead of PSA/Renault/Ford/GM etc. They are all covered good, at a reasonable price.
And you already proven to solve mostly of the other high security systems.
Add on soft to the HW. Don't need a new box.
Cover what A_Vdi does, and you got a hit.
obdsystems (15th December, 2017)
For those who say it doesn't work without working key, this is body from bravo2 2008 connected on the table read, write all ok
what model Fiat has MCU NEC 70F3633 in body ?
Lads why spend money on tools? For most Fiat cars you need to spend more then just pulling pincode!!!
You also need to precode the transponder the cheapest way I have found is bsi out of car read chip and get pincode with Eefi then precode the transponder all done with free Eefi software why spend money when all this will be done in 20min…
zyjekrc51 (10th December, 2017)
