advanced diagnostics tool will do most by obd. avdi will not pull pincode by obd, will only do programming. you also need precoding for transponder.
Advanced Diagnostics tool does not pull the PIN.....in fact their instruction manual reference to get PIN from dealer.
doctore (10th December, 2017)
Hello Friend! I'm ABRITES Diagnostics charge for Fiat / Lancia / Alfa / FCA, and does not read the PIN. I have to read the file to get the PIN with other equipment. I use the UPA. After presenting the key by OBDII with AVDI.
Solutions in the area of automotive coded keys, all automakers.
super jumbe (10th December, 2017)
Best fiat. (( OBDMAP by chiptronic brasil )
Bc
box
Painel
http://www.asbrac.com.br/dicasemacetes/Manual-OBDMap-CODE2-BC-Rev.%202.pdf
T-code and Zed-Full can read pin code in fiat and pre code tranponder whiteout remove BSI.
Zed-Full performs the entire job of coding key in less than 5 minutes.
For same fiat bsi reading/writing
http://ioterminal.com/?page_id=391
Smok could be a options! FT 0013 Fiat BODY OBD
From what years, and which models are the ones, that you would like to do?
hbt (11th May, 2016)
tm pro 2, tango, avdi, remap3, so many tools,
If working key is not present,ignition on for 15 minutes,then read.
