Have you set up your location to do a vm scan............Paul
PAUL
Is there any help on this subject? Im strugling to get a full scan on this image too.it wont accept my netid frequency and symbol rate it just says no bouquets found.It will only scan areas miles away after i set my location and run auto bouquets
Sent from my SM-G900F using Tapatalk
i mean it is for hub channel
Why would you set it for UK then? You need a cable.xml for your area which I can only presume may be available?
I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
