Hellom
Could you please decode a PIN from one bin file and virgin the other one? I need to replace BSI.
Could you also propose any software for that kind of calculations, so I won't bother anyone in the future?
BSI.zip
Hellom
BSI.zip
K1A4.... and Hexworkshop is what you need ..
PS ... why not just change the eeproms ove r
Adam871 (12th May, 2016)
Hmm... I'm not sure but I remember that once in older BSI from some P206 or smth it wasn't possible - something went wrong Since that time I'm trying to clear and configure BSI like its a new one..
So you advise is to just resolder eeprom from one BSI to other one and should be working fine?
to clear bsi maybe would be enough FF eeprom.
Not sure if swapping eep would work, unless numbers are the same.
In C4 you can't fill eeprom with ff, it won't turn ignition on. If you change eeprom, if software versions are different it will erase immo data, Just init bsi and keys and you're done.
Write your old BSI eeprom to donner. If diffrent software, under Lexia, BSI become virgin.
Just recode BSI like a new one with pincode.
