Results 1 to 5 of 5
    Jul 2012
    Default John Deere tractor claas ERROR ECU TEMP
    Hello guys...
    I have one ecu from Tractor John Deere Claas (I think)
    The nubmer from ecu is
    L12/12V
    P/N: RE532627
    S?N: 608775
    This ecu have fault with temperature says engineer and now cannot start the engine
    With a new ecu the tractor works perfect!!!
    Maybe any friends has any idea about this problem or has any solution
    Thank you!!
    Jul 2012
    Quote Originally Posted by ChipDoctor View Post
    Hello guys...
    L12/12V
    P/N: RE532627
    S?N: 608775
    Thank you!!
    morfej has exceeded their stored private messages quota and cannot accept further messages until they clear some space
    Jun 2018
    Hello
    Check the resistors with the designation 7500, which is probably damaged, additionally replace the capacitors 100uf 35v, the temperature of the exhaust should be returned to normal and the engine should be started.
    Mar 2015
    hello friend you could solve the problem of the ecu
    as?
    castin's Avatar
    Oct 2015
    I hawe the same ecu with engine temp sensor. ChipDoctor, solution mgrslonio worked?
